Registered Member #3414
"Oxygen becomes a liquid at temperatures below its boiling point of -183 C and takes on a pale blue color weighing 1.14 times the weight of water. When the temperature of liquid oxygen is greater then -118.6 C, the liquid will return back into a gas regardless of the pressure exerted on it. This is known as the critical temperature. 1 Liter of liquid oxygen provides 860 Liters of gas."
Registered Member #3766
Ash Small wrote ...
"Oxygen becomes a liquid at temperatures below its boiling point of -183�C and takes on a pale blue color weighing 1.14 times the weight of water. When the temperature of liquid oxygen is greater then -118.6�C, the liquid will return back into a gas regardless of the pressure exerted on it. This is known as the critical temperature. 1 Liter of liquid oxygen provides 860 Liters of gas."
but oxygen also has a critical pressure at which it will liquify at standard temperature,
Registered Member #193
magnet18 wrote ...
Ash Small wrote ...
No, it will not. That's the whole point of a critical temperature. Above the critical temperature, no matter how high the pressure, it will not form a liquid.
Doh, I feel dumb now, it would go to supercritical phase, wouldn't it. hmm... maybe I could place the dry ice in alcohol to cool the alcohol beyond the 198K where dry ice sublimates... but everything would bank on the dry ice having an internal temperature below 154k
Registered Member #2099
If you want to liquefy air or O2 at home, the dry ice & alcohol might be a good start. Decades ago they talked about this sort of stuff in the Amateur Science column in Scientific American.
I haven't run the numbers, but I bet one can reach 77K with a single expansion stage and regenerative cooling. Google the invention of liquid air machines (mid to late 19th century?). Here's a starting point:
1. Compress a flow of air or O2 to high pressure, or draw it from a high pressure tank. (Well respecting the hazards of mechanical and pyro explosions. It would be safer to start with gaseous N2 ).
2. Run it through high pressure tube immersed in ice water (optional), then dry ice/alcohol, so you have high pressure gas (or supercritical fluid) at 195K.
3. Then the high pressure tube runs -inside- a low pressure tube, all coiled in a well insulated enclosure. The outer tube carries cold gas flowing in the opposite direction, and the pair form a counterflow heat exchanger.
4. The high pressure tube ends at a flow-limiting orifice, porous plug, or length of capillary tubing. When the gas is cold enough before the expansion, some may liquefy. What doesn't liquefy and drip into the collecting flask is made to return through the outer tube. (Think about a loose-fitting 1-hole stopper made of nonflammable thermal insulating material).
Of course it's trivial to make LO2 if you have a source of GO2 and plenty of LN2.
