  • Guests: 50
Linas (34)
Toasty (29)
05/16 kg7bz (68)
05/16 steve516 (31)
05/17 Finn Hammer (72)
electrolyte for etching aluminum
ZakWolf
Tue Jul 19 2011, 08:25AM Print
I read that making a black etch mark on aluminum requires DC and a special electrolyte, I cant seem to find anything on the intertubes and was wondering if any one knew of such electrolyte.
Ash Small
Tue Jul 19 2011, 09:45AM
I've not read this fully, but apparently you don't even need electrolysis, just HCl and H2O2
There are a few ideas here:
Link2,or.r_gc.r_pw.&fp=1cf90f5820d223e3&biw=1366&bih=65 3
I don't have any personal experience of this myself, but I'm interested in giving it a try.
ZakWolf
Tue Jul 19 2011, 10:04AM
Yeah i saw that instructable but i just dont want to deal with any acids, i have all the electrical equipment i just need to know what metal an electrolyte to use, hopefully something common and maybe even house hold.
Pinky's Brain
Tue Jul 19 2011, 01:54PM
You can get anodization kits for aluminium, these form a porous aluminium oxide layer which can be dyed.
Tue Jul 19 2011, 04:48PM
There's nothing critical in electrolytic marking. Try salt water to start with. Ought to make a decent, permanent mark on aluminum in a couple seconds. (If the Al surface is already anodized, thus nonconductive, then you're SOL.)
In a typical commercial system, you: Link2
1. Make a stencil of desired mark. They sell special coated paper like old mimeograph stencil stock, that becomes porous when typewritten on. Now go find a typewriter. smile
2. Stick the stencil on the workpiece.
3. Choose one of their proprietary electrolytes, depending on your metal.
4. Use electrolyte to dampen a metal-backed felt pad, which is the tool.
5. Connect their DC power supply to the workpiece and the tool.
6. Apply tool to stencil for a while (10 seconds max).
I still have some high-speed-steel endmills, on which I etched my name at a summer machine-shop job 35 years ago. The marks look good as new.
Tue Jul 19 2011, 06:04PM
Interesting, some EL panel manufacturers use this in their "ICEbrite" technology to increase the contrast ratio.
-A
ZakWolf
Tue Jul 19 2011, 08:44PM
thanks, I will try the salt water but what other metal do i need, will steel work, i thought different metals plated different things. To make a black mark I guess i need DC for aluminum, but i will try both.
Wed Jul 20 2011, 03:03AM
It doesn't much matter what the tool backing plate is made of.
The workpiece is positive and the tool backing plate is negative.
You are _removing_ metal from the workpiece, not plating metal onto it from the electrolyte.
The mark is black because of microscopic roughness or a secondary chemical reaction.
See: Link2
[edit] the top two comments on the you-tube video are stupid.
They claim that the salesman demonstrates the process on one side of a knife,
then cuts to a close-up of the result on the _other_ side of the knife.
To my eye, it's just a different view of the same side of the knife.
Reminds me of this video of a narrowly-tuned tethercar reaching 200 real (not scale) MPH.
Dummies are always posting comments calling it fake, with various stupid arguments. Link2
[re-edit] On closer inspection, the knife-marking demo does switch sides between
application of the tool and close-up off result.
ZakWolf
Wed Jul 20 2011, 03:26AM
so i will try with some salt water, AC or DC what voltage?
Ash Small
Wed Jul 20 2011, 01:25PM
SublimeVolts wrote ...
DC. Workpiece is positive (anode).
The critical factor is current/area (amps per square metre, or in this case per square millimetre)
I'd start by making a saturated solution of salt water by boiling the water with excess salt, You may find that temperature also has an effect on rate of etching, current required, etc.
Start with a low voltage. if nothing happens, increase the voltage. (or try limiting the current with a resistor, light bulb, or whatever, it's the current that is the critical factor, not the voltage)
Distilled or de-ionized water may be better than tap water, but I don't expect it will make a lot of difference.
(I might try this myself)
