  • Guests: 39
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
another smd removal method
Psyko
Thu Jun 22 2006, 09:59AM Print
Psyko Registered Member #81 Joined: Thu Feb 09 2006, 11:57AM
take an horizontal toaster, your board, and voila, almost nothing remains on.
It works wonderfully with modern pcbs, you can remove smds as well as through hole components.
1150970374 81 FT0 Photo 2089
Marko
Thu Jun 22 2006, 10:34AM
I used common high-temperature fan for unsoldering almost anything (not just smd).
It can easily heat lots of pins together without overheating conponents for much.
Maybe a hair-dryer would also work, possibly motor would need to be slowed down, and plastic parts removed from the cavity.
There is also a termal sensor that would need to be disabled.
I didn't try this as I'm happy with my current fan.
ragnar
Thu Jun 22 2006, 11:11AM
Lovely, psyko!
But why not a normal toaster? Just drop the board in, set it it to "nuke", and retrieve your components from the crumb tray! ^^ ROFL
Completely automatic! wink
Well, might need occasional agitation/jiggling to get the more resistant (pun not intended) components to drop off.
Thu Jun 22 2006, 12:39PM
i'd be real careful about how much heat a toaster gives off. you could very well be damaging the pads on your board causing them to delaminate from the FR-4.
Michael W.
Thu Jun 22 2006, 02:19PM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
Unless a component falls off and bridges a heating filiment...~SHORT!~... cheesey
GimpyJoe
Thu Jun 22 2006, 05:05PM
Do you put it on component side up and then whack the board on a table to make the components fall off?
Psyko
Thu Jun 22 2006, 07:36PM
Board facing up on the toaster, I just remove the components one by one. This method was inspired by Link2
It is kinda magic, it is as if components were never soldered.
I was able to remove a whole pentium socket very easily with this method
Thu Jun 22 2006, 09:26PM
Just curious - why would you want to remove all the components from a board anyways? I personally can't think of any reasons why one would do this.
Marko
Thu Jun 22 2006, 09:41PM
So you can trash thm and save big amounts of space.
Tiny unneded conponents can also be removed easily and trashed saving even more space.
(Rich people who buy just everything usually don't understand us Scavengers)
Fan worked excellently for me, it can heat precisely as much as needed and conponents can be removed far before they reach temperature of the solder.
Toaster is fine as long as you can save the board and conponents before burning out, that seems a bit trickier with toaster.
Psyko
Thu Jun 22 2006, 09:42PM
It's my pleasure tongue Just kidding. When you have found something powerfull, you try it with everything you can to improve the process. Actually, all the boards I build today are nearly full cms. With my brand new toaster, I have all components I need.
