  • Guests: 29
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Coil Making 101: Pancake Coils
FastMHz
Wed Jun 21 2006, 10:33PM Print
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
I've gotten a few requests from folks wanting to know just how I create those flat coils to launch rockets and other objects...well, I decided to create a video tutorial to show the entire process:
Video Tutorial
Thu Jun 22 2006, 12:12AM
seems like it would make things go a heck of a lot faster if you put your drill in the vise, then the bolt in the drill, put on a pair of gloves to prevent cutting your fingers on the wire, slowly giving the drill some juice and holding the wire tight... It would also (probably) result in a more regular coil wink
Looks good in any case!
FastMHz
Thu Jun 22 2006, 04:31PM
I agree that using a drill in a vice does seem easier, but it actually makes it harder to get a regular coil as the wire will start overlapping itself and you end up with an uneven coil. This is because the bolt flexes too much. I actually spent more time fighting the drill method and re-wrapping 3 times until it came out right than I did doing it once manually.
Anyway, that coil in the video is now complete, has 3 layers and I will wire it up and start testing it soon. This is my first 3 layer coil!
