  • Guests: 56
mileswaldron (59)
06/03 mileswaldron (59)
06/04 muze801 (33)
06/05 HVgeek (33)
Would these caps work?
currentkills91
Mon Jun 06 2011, 06:58PM Print
Okay, so im browsing Ebay looking for the caps i wanna get for my coilgun project and i ran across these. My only concern is, is that the leads look really small. Those caps will have to dump over 600 amps and im just wondering if they would do the job?
Forty
Mon Jun 06 2011, 07:38PM
just drill some holes through copper strips like these (or cut your own) and solder them on as bus bars as close to the caps as possible w/o melting them. that should work out alright. i made a lot of capacitor banks in the past with very poor connections and never had anything explode (well, except for improperly located diodes)
Navrit Bal
Tue Jun 07 2011, 03:49PM
Navrit Bal Registered Member #3323 Joined: Sun Oct 17 2010, 03:19PM
Could I recommend not soldering since you might damage the capacitors and it might be very hard to remove. If you can, try using nuts and bolts etc, as long as you screw them fairly tightly, you shouldn't have any issues with poor connections (I haven't anyway :D). Also you will almost definitely want to change the arrangement at some point, so if you solder it you might encounter such issues.
Anyone else, please feel free to correct what I've said!
Dr. ISOTOP
Tue Jun 07 2011, 04:30PM
'tis a bit hard to bolt down caps with no screw terminals wink
@OP: you should look for the big 450V 'lytics that appear on Ebay; best I've seen is ~700J for $9.
currentkills91
Tue Jun 07 2011, 11:34PM
Yeah ive managed to find 10-450v 560uF caps so im going with these...thanks for the help though (:
Navrit Bal
Wed Jun 08 2011, 10:35PM
Hehe sorry, I just assumed that they would have screw terminals :D
