  • Guests: 35
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
vacuum spark gap
Coronafix
Mon Jun 19 2006, 03:40AM Print
Has anyone done any testing using a static spark gap ander vacuum?
I'm just wondering what the pros and cons of this would be.
Seems that it would be fairly simple to build one.
Madgyver
Mon Jun 19 2006, 06:08AM
Is it? Unless you have good vacuum 'source' at hand that will prove difficult. Just pumping out lots of air an leaving behind a lot pressure gas, won't make a good spark gap.
Even if you could, x-rays could be a major issue here.
ragnar
Mon Jun 19 2006, 07:32AM
X-rays? Pshhh... what's new? ^^
You'd need a real 'high' vacuum... how about a sulfur-hexaflouride filled relay / sealed contactor box instead? :)
Coronafix
Mon Jun 19 2006, 10:13AM
What about using an old fridge compressor, or two? That would get a decent vacuum.
A lead box over the vacuum would stop the x-rays.
SpyrosF
Mon Jun 19 2006, 10:28AM
SpyrosF Registered Member #352 Joined: Tue Mar 28 2006, 08:39AM
Vacuum is not conductive, except of course thermionic emissions.
look here -> Link2
Dr. Shark
Mon Jun 19 2006, 12:01PM
Nope, an old fridge compressor would be _very_ far from sufficient. Even a $2000 two-stage rotary vane pump hardly gets you down to "real" vacuum where you begin to get x-rays, for a serious hard vacuum you need a two stage vacuum system with a turbomolecular (figure $5000) or similar pump. You will run into lots of issues with contamination, and you will have to bake the system (oven, another couple of k$) while pumping it down. Expect to spend several $1000 even if you buy used or make your own equipment.
That being said, vacuum gaps make excellent HV switches, and I have come aross them several times in a railgun context. Similar to big thyratrons they can switch 100s of kA and are very fast. I don't quite know how they work, but I expect some of the metal from the electrodes evaporates to produce a conductive plasma.
Coronafix
Tue Jun 20 2006, 02:28AM
SpyrosF wrote ...
We are talking electron transfer, and I'm not wanting to produce x-rays anyway, just improve the efficiency of the static spark gap.
Maybe I should have asked the question..."Has anyone used a static gap under a partial vacuum and if so, are there any noticable benefits?"
Michael W.
Tue Jun 20 2006, 04:03AM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
Heres a small one for sale on ebay
Its sort of expensive...
Coronafix
Tue Jun 20 2006, 05:30AM
now thats what i'm talking about!!
that one looks adjustable, but I don't know how that would work and keep a good seal.
I read somewhere of someone getting 50% effeciency, but no details were mentioned.
SpyrosF
Tue Jun 20 2006, 05:45AM
Try a pressurized spark gap, it's able to handling higher currents and has faster switching,
better timings, lower losses and lower jitter.
Take a look at this links:
