  • Guests: 21
  • Members: 1
Cprossu (40)
Kokamo (46)
GalliumMan (60)
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
MICRO pulse jet
Bjørn
Sat Jun 17 2006, 11:47PM
How can the cylinder exlpode when it contains no oxygen?
Acetylene is not a stable gas and may explode for no reason unless it is stored and handled correctly. Explosions are rare but when they happen they will demolish a house completely or a car for that matter. Even fairly small amounts can cause serious destruction.
1150588033 27 FT11561 Pickup
Jim
Sat Jun 17 2006, 11:50PM
Jim Dunce.
Registered Member #28 Joined: Fri Feb 03 2006, 03:29AM
Wow, off topic comments contributed to by moderators.
I believe the correct course of action would be to have split that off into another thread concerning explosive gasses.
dorks.
Acetylene is a very forgiving pulse jet fuel, it will make even the worst designs run, or almost run.
Bjørn
Sun Jun 18 2006, 12:19AM
Since it was not clear if you had any idea what you were doing it was considered to be 100% on topic so you would not blow up yourself and everything around you.
Jim
Sun Jun 18 2006, 03:34AM
Jim Dunce.
Actually it was not. Considering how I had mentioned that I do have the proper safety equipment in my set up, there was no need for you to carry on a completely off topic discussion concerning the explosiveness of acetylene.
I have had some problems with the engine body (standard brake line) softening with the head, and sagging. Perhaps some stainless brake line would hold up better.
Sun Jun 18 2006, 03:54AM
Considering some of the recent photos you posted of yourself doing incredibly dangerous and stupid things with fire, its downright obvious you DO NOT know the proper safety precautions when it comes to this stuff. (See image below)
1150602842 15 FT11561 Jj01
Richy
Mon Jun 19 2006, 11:26AM
Richy Registered Member #121 Joined: Fri Feb 10 2006, 12:39PM
Wow that's a pretty neat little engine. Did you use the Acetlyne with air or pure oxygen?
Richy.
GimpyJoe
Wed Jun 21 2006, 08:12PM
Ah, another pocket locky clone. You, sir, are from the pulse-jets.com forum, aren't you?
