  • Guests: 9
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Switching for my coilgun project
AdamF
Sun May 01 2011, 09:37PM Print
AdamF Registered Member #3603 Joined: Tue Jan 11 2011, 11:21PM
Hello guys,
I'm thinking of budget ideas for switching my cap bank into my coil gun for firing. Would it be stupid to put copper contacts on a mousetrap (via lots of solder and a mechanical linkage as well) and use the trap as a high-speed switch? My cap bank is 3600uF at ~415v. I have thought about getting an SCR but if something less elegant would work I am all for not waiting for one to get shipped to me.
I like the trap idea right now because it will allow me to be far away from the firing in case something else goes wrong; since I'll be doing a demonstration at school I think that would be best.
Thanks!
Myke
Sun May 01 2011, 10:01PM
There was this mechanical design I saw one time where someone used two pieces of copper as contacts and used a solenoid to wedge another piece between them. They used something like an 8 degree angle to keep the copper sticking to prevent contact bounce. It worked really well for them and there was no welding as far as I know. I'll see if I can find the page again.
EDIT: Found it. Link2
Mon May 02 2011, 02:07PM
The requirement for mechanical switches is maximum contact area and minimum contact bounce.
Remember, most small-signal switches have contact bounce up to 15 msec before it's fully settled. However, most coilguns have an entire firing time of 4 msec or less. Any bounce during this time can cause arcing and welding.
I built a wedge contactor switch from ideas used in high power commercial switching a few decades ago. I've scoped it and found zero bounce (at least at low voltage, lol). However, now I still need to finish the coilgun and see how it performs under load. I plan to return to this coilgun in late summer and see.
Cheers, Barry
Technology is a way of studying the universe so man doesn't have to experience it firsthand
