  • Guests: 38
mileswaldron (59)
06/04 muze801 (33)
06/05 HVgeek (33)
06/05 jmorlockny (50)
What magnetic force do I need
Tim
Thu Apr 28 2011, 10:33AM Print
Tim Registered Member #3851 Joined: Thu Apr 28 2011, 10:20AM
Hello, I'm quite new to this technology, but I'm trying to understand the theory of magnetic forces.
I'm trying to build a system where a projectile (x inch ball) needs to be fired vertical to a speed of y feet/second. This is to be done with use of 5 coils in a row. Each needs to accelerate the ball so that the eventual speed is achieved.
How can I determine:
- The magentic power needed from each coil.
- The size of the coil
- The current needed in the coil.
Rustycan
Thu Apr 28 2011, 03:03PM
Rustycan Registered Member #3805 Joined: Sat Apr 02 2011, 09:06PM
AFAIK You don't need to determine current, the more you bring the more velocity you'll get. As long as the coil could handle te current.
For the others you could mix your best using barry's sims
Thu Apr 28 2011, 04:15PM
Tim wrote ...
- The magnetic power needed from each coil.
Welcome to the forums!
You'll want to start with the basic energy budget needed for the ball. Given mass and required initial velocity, you'll know the kinetic energy required. Divide this by the number of coils to get the kinetic energy needed from each coil.
Multi-stage coilguns can reliably impart a certain amount of kinetic energy per stage. That is, if each stage has the same capacitor (joules of stored energy) then you can design a series of coils each with its own timing to add about the same kinetic energy each time. The point is, each stage can provide the same change in kinetic energy; this not the same as "the same change in velocity".
Having done that groundwork, the hard part is choosing each coil's inductance and timing. I suggest designing and building the first stage alone to learn the process and discover what efficiency is achievable for your chosen approach.
Cheers, Barry
Any intelligent fool can make things bigger and more complex... It takes a touch of genius to make difficult things simple.
