Registered Member #2680
I built a simple marx generator that produces less than 100kV. Every time the marx generator fires (or misfires), the LCD displays displays nonsense numbers. I tried to increase the distance(to 1.5 meters) between the marx generator and the power supply and that made no difference. I put a TVS diode and a 0.1uF cap in parallel with the marx generator and the power supply, and also an inductor in series, but this made no difference. Is there anyway to fix this problem?
Registered Member #2431
Marxist (and Communists) tend to be harsh on digital meters with e-fields and M-fields. Yes I agree youll need a faraday cage out of screen-door screen or something similar. Remember its radiating these fields of interference everytime it strikes, so the usuall tricks for conduction interference dont work so well, TVS's, Caps. (at least with out the faraday cage)
I never built a faraday cage before. Should the cage be grounded to the ground clip of the power supply or to earth ground? How small should the hole/mesh size be? What's the ballpark frequency of the radiation emitted?
Registered Member #1875
Dosinski wrote ...
They should be the same... And if they aren't, I'd see to it that they are.
Dosinski wrote ...
Ideally you could just use a metal box or cover the enclosure with aluminum tape or foil to be safe.
Dosinski wrote ...
High. Your resonant circuit is composed of the series sum of your capacitors' capacitance and the stray inductance of your wiring and that of the spark gaps. So, high and not easily measured.
Registered Member #1225
ScotchTapeLord wrote ...
Dosinski wrote ...
Well it seems like the frequency wouldn't be too high to be measured by a DSO. Even an old 25MHz analog scope can measure a HF vttc which the resonator is much less than 10pf and 20 turns of wire. Im sure the inductance of his wiring and the capacitors would equal a few windings and the capacitance is likely to be over 100pf. But still, the voltage would make it hard to measure
Regardless, that would place the frequency in the MHz which sure would radiate plenty of energy.
Registered Member #96
I had a similar problem once with a calculator which failed when "flashed" from across a room with a commercial high power flash unit. This same unit would actually blister black plastic and disks at a range of 1cm (!) to the point that smoke was emitted.
Appears that the light hitting the inadequately shielded chip may have been responsible, as shielding it with cardboard removed the effect. -A
