  • Guests: 24
Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
Cool chemistry experiment . . .
Thu Jun 08 2006, 03:27PM Print
http://www.math.utah.edu/~c-pnkk/mentos.html
This is probably old news, but i'll post anyways.
Dr. Shark
Fri Jun 09 2006, 09:11AM
I didn't know it, pretty cool - what is the explanation how it works? It does not come up when I klick on it.
Fri Jun 09 2006, 02:33PM
If I remember correctly there is a compount (something gum) that lowers teh surface tension of the water, lowering the amount of CO2 it can hold, so it all suddenly bubbles out, causing quite a display shades
Bjørn
Fri Jun 09 2006, 03:23PM
Why would the gum arabic be on the outside when it is supposed to be chewy inside? I would not bet on that explanation until someone actually tried it out instead of guessing.
ShawnLG
Fri Jun 09 2006, 09:10PM
What would happen if you consume both of those products at the same time? Would you explode?
Bjørn
Fri Jun 09 2006, 09:50PM
No, it comes out the same way it got in. Except for the very last part of the journey where it has a tendency to come out through the nose.
Eric
Fri Jun 09 2006, 10:03PM
Eric Registered Member #69 Joined: Thu Feb 09 2006, 07:42AM
There have actually been rare cases of stomach rupture due to ingesting gas producing substances (sodium bicarbonate for ex). I wouldn't try it.
Fri Jun 09 2006, 10:33PM
this should clear up any confusion...
Fri Jun 09 2006, 10:35PM
You have any evidence, links?
Except maybe producing some mega-burps I don't think anything more would happen.
Most CO2 ill evaporate anyway before such a quantity of coke gets into your stomach (otherwise yu would blow up anyway yust for drinking aerated drinks :P )
Fri Jun 09 2006, 11:37PM
Was that comment directed at me or Eric?
The coke does 'boil' pretty rapidly, check out those videos... If you drank a single can of soda (500ml) that would be 1/4 the gas produced of the 2L, not something I wound want in my stomach... The video of a 2L bottle can be found in the link in the first post.
