  • Guests: 29
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
best mosfet
Microwatt
Sun Mar 13 2011, 07:51PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
what is the best mosfet for a mazelli driver?
Sun Mar 13 2011, 08:27PM
Oh come on, that's like asking "What is the best tire for a car".
Most people use whatever MOSFET they can find cheaply at their local surplus electronic store or on Ebay. The IRFP250, IRFP460 etc are old favourites.
The MOSFETs need to be rated for pi times the supply voltage. If you want to run the thing off a high voltage, IGBTs start to become attractive. Mazzilli's original oscillator actually ran off 320V DC and used 1200V IGBTs: the BUP314D from Siemens/Infineon, which was available cheaply in Europe at the time.
And by the same token, if you only have a very low voltage power supply, like a 12V battery, then you should be looking at 50V or 100V MOSFETs, these are available with extremely low Rds(on) for efficient operation.
So, in other words, it depends on what kind of car and where you're going to drive it. tongue
HazzWold 1993
Sun Mar 13 2011, 09:50PM
Steve McConner wrote ...
Well you learn something new every day, thanks for the fun fact!
haxor5354
Sun Mar 13 2011, 09:51PM
I don't always buy with mosfets, but when I do, I prefer IRFP260
Microwatt
Mon Mar 14 2011, 01:42AM
the most interesting semiconductor in the world?
James
Mon Mar 14 2011, 02:22AM
I'm using IRFP240s in one, but almost any mosfet with sufficient voltage and current ratings for the power you wish to run it at will work. With low resistance mosfets you don't even need a heatsink in most cases, but I did blow a mosfet once due to thermal runaway when I was pushing ~400W through the driver to do induction heating so a small heatsink is recommended.
If you want to run it from higher than about 60V, I recommend improving the gate drive arrangement a bit, something like this Link2 There are of course a zillion different choices for the gate driver and since they're both low side you don't have to use fancy expensive HV floating gate drive ICs.
