  • Guests: 70
mileswaldron (59)
06/03 mileswaldron (59)
06/04 muze801 (33)
06/05 HVgeek (33)
charging circuit
lewylln
Wed Mar 02 2011, 06:53AM Print
lewylln Registered Member #3358 Joined: Mon Oct 25 2010, 09:47AM
alright i have the construct, cap bank and everything working perfecting, the rails are in line and all that however when i charge the cap bank and fire the feed back (guessin thats the term) literally blows my charging circuit. Im using a camara circuit board as most ppl seem to use but it doesnt handle the brunt of the charge as it returns from the cap bank (i really hop i get this right). so im wonderin wat i could use to replace this and make a circuit from scratch which can handle the full force of lets say, my 50 cap bank at 300v and (guess i dunno) like 100-200uf charge. If any1 can gimme ideas on how to build this or a way to get the charge it'll be appreciated. My only current idea is to buy or make a 1:20 (or something of the sort) charge transformer to up the voltage but im not sure how smart or wise that is.
lewylln
Tue Mar 08 2011, 03:07AM
so no1 has no clue as to wat i could do?
genious 7
Tue Mar 08 2011, 03:18AM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
You did place diodes to avoid negative voltages due to indutance, didn't you?
Andyman
Tue Mar 08 2011, 04:02AM
You should be charging through a resistor, and also disconnecting the charging circuit before firing
Turkey9
Tue Mar 08 2011, 07:47AM
Revert to what all people who have asked this question are told: use Uzzor's boost converter. Simple, powerful.
lewylln
Wed Mar 09 2011, 07:16AM
scratch that last one, im lookin into the " Uzzor's boost converter" sounds good to me
haxor5354
Fri Mar 11 2011, 04:01AM
coil your own flyback transformer to output about 300volts and drive it with Mazilli's flyback driver
