  • Guests: 13
hvguy (41)
thehappyelectron (14)
Justin (2024)
05/15 Linas (34)
05/15 Toasty (29)
05/16 kg7bz (68)
Can you use Tiki torch fuild for tennis ball mortars?
CokeCanNinja
Tue Feb 22 2011, 06:35PM Print
CokeCanNinja Registered Member #3706 Joined: Mon Feb 21 2011, 04:17AM
I have a 1/2 gallon jug of Tiki torch fluid, but no Tiki torches, and I'm building a tennis ball mortar. Can I use the torch fluid in the mortar?
Tue Feb 22 2011, 07:14PM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
Tiki torch fluid is (I assume) paraffin (or similar) so would be very hard to use as a propellant fuel.
Martin.
CokeCanNinja
Tue Feb 22 2011, 08:50PM
I tried it just now, didn't work worth bubkus.
Adam Munich
Tue Feb 22 2011, 11:53PM
Here's an idea:
*Soak the tennis ball in tiki oil.
*Light it.
*Put it in a trebuchet.
*Attack the neighboring castle with fireballs.
Muttyfutty!
Wed Feb 23 2011, 06:20AM
Muttyfutty! Registered Member #2915 Joined: Fri Jun 11 2010, 10:41AM
Or even better, fill tennis balls with lighter fluid and put a dozen in a trebuchet...
Wed Feb 23 2011, 07:25AM
or be a real man with huevos, and use a basketball full of PETN, trebuchet that out and see what happens!
Adam Munich
Wed Feb 23 2011, 07:50AM
Paraffin oil is what fire breathers use right? wink
Ash Small
Wed Feb 23 2011, 02:47PM
Grenadier wrote ...
Paraffin is known as kerosene your side of the pond.
