  • Guests: 22
hvscrapper (40)
11/11 Firefox (35)
11/11 ElectronicBob (38)
11/12 jake3085 (28)
What are the most interesting vacuum tubes in your collection?
1 2 3 4  last
radhoo
Sat Feb 19 2011, 09:51AM Print
Even if they are considered obsolete by some, the vacuum tubes still provide interesting applications, and in some cases are irreplaceable by silicon.
I hope that other members will join and contribute, based on their experience and knowledge.
I suggest we build this thread, to contain the best of our tube collections, like a virtual museum, if you want.
If possible, please try to upload quality photos, that others would enjoy seeing.
Also based on your knowledge it would be great to include a few words on the purpose of the vacuum tube pictured. This way we all get to learn something. So here it goes:
radhoo
Sat Feb 19 2011, 09:54AM
Transmitting Triode 710A (200W, 600MHz max)
19 57 26
More details available here:
Sat Feb 19 2011, 12:20PM
EF97 - low voltage variable-mu pentode
So why this modest looking valve instead of the usual 4HV power porn?
1298115009 543 FT0 Ef97 Edit
EF97 was designed to be fully functional with an anode voltage of as little as 6.3V, with the screen grid at a tiny 3.2V.
1298115050 543 FT0 Ef97 Upload
EF97 ran directly from a car battery, and so did away with the need for costly HV batteries, vibrating reed invertors, or dynamotors usually required to supply anode voltage to car radio reciever valves.
Its heyday in car radios and record players was shortlived. Manufacture began in 1958 and had ended by the mid-60s, a period of radical transition in the electronics industry. The Thermionic Age was coming to an end, and the Solid State Age had just begun, so EF97 and its fellow car radio valves were quickly forgotten when germanium transistors began to appear in commercial designs.
But for the experimenter, the car radio valve remains an easy way of getting into thermionic technology without the danger of electric shock, or the need for specially built smoothed HT power supplies.
Some, but not all, of the car radio valves worked in space charge grid mode. In these valves, such as 12K5, g1 is designated as 'space charge grid' and held positive as an electron accelerator, while g2 - normally the screen grid - is designated as 'control grid.' Check the data sheets to avoid mis-wiring.
There are plenty of 'space charge tube' circuits to be found on Google.
1298115081 543 FT0 Ef97 Datasheet Extract
radhoo
Sat Feb 19 2011, 03:51PM
714 7021 Gas and Mercury Thyratron.
A thyratron is a type of gas filled tube used as a high energy electrical switch and controlled rectifier.
I might try one of these in a small SG tesla coil, as a spark gap replacement.
16 10 11
The datasheet, as PDF: ]714_7021.pdf[/file]
Sat Feb 19 2011, 09:04PM
1298149067 205 FT109016 300b
300B is an audio power triode, here in a recent version with globe shaped envelope.
Audio lore (or hype if you wish) has it that the globe shaped tubes sounded better, thus there was a market for this variety.
What I find interesting about this valve, is that it has acheived cult status amongst audiophiles, and therefore can be sold at prices that are much higher than that charged for even bigger valves.
That's the way it is amongst audiophiles.
Cheers, Finn Hammer
radhoo
Sun Feb 20 2011, 11:13AM
Reflex Klystron 6236, with a frequency range of 3.8 to 7.6 GHz with 125mW output.
Klystrons are used as amplifiers at microwave and radio frequencies to produce both low-power reference signals for superheterodyne radar receivers and to produce high-power carrier waves for communications and the driving force for modern particle accelerators.
This tube was used by the military, judging by the output power it probably functioned in a RF generator.
19 26 39
A circuit using this klystron:
1298200408 1938 FT109016 6236
Taken from: Link2
Wish I had more data on it.
Bored Chemist
Sun Feb 20 2011, 01:39PM
I don't collect tubes, but I have a dead 3CX1500D3 I use as a paper weight.
radhoo
Sun Feb 20 2011, 02:33PM
Bored Chemist wrote ...
Would you post a photo?
Wolfram
Mon Feb 21 2011, 12:55PM
These are about half of them. The biggest tube in the first photo is the same size as the smallest one in the second
1298292762 33 FT1630 Dsc 4949
1298292762 33 FT1630 Img 0356
Mon Feb 21 2011, 01:05PM
I have lots of other tubes, but this one is most in the "4HV Power Porn" spirit. I would like to build a RF amp with it some day.
Finn, are you still using that beautiful 300B hi-fi amp I saw when I visited you in Denmark?
1 2 3 4  last
