  • Guests: 24
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
DRSSTC III Photos and "How to kill a Secondary"
Fri Jun 02 2006, 01:07AM Print
Here are some first light photos of the DRSSTC III system. The first is during a run this evening.
I finally killed my secondary in the last run. Notice the green glow from the copper burning and the pieces of schrapnel going every which direction. Totally cool!!! Luckily, i have two more to destroy before i have to make new ones!!! I coated one side with epoxy (only had one tube of it), so that was pretty bombproof, but the other side (which is what burned up) only had a thin coat of acrylic enamel on it.
Enjoy!
1149210434 15 FT0 Drsstc3 01
1149210434 15 FT0 Drsstc3 02
Fri Jun 02 2006, 04:57AM
Cool! Thats a really impressive spark output for that coil! Any IGBT deaths yet?
Are you running primary feedback with these coils?
Desmogod
Would it be possible to get an acrylic tube _just_ a bit larger than the secondary, slip it over the top then fill it with epoxy?
Might help with the issues?
ragnar
Fri Jun 02 2006, 10:44AM
Aw, nice, EVR =)
Love the pics, I was holding out for these for days...
In the first photo though, did you do nearest-neighbour interpolation when resizing?
Very impressive flashover!
Fri Jun 02 2006, 11:56AM
Thanks for the comments.
Steve,
I did kill (2) IGBTs on the first night. I disabled my current limiting circuit and was really pushing the coil. This coil does use primary feedback.
Desmogod,
Yes, that is a possibility, although i'm going to try a couple of coats of epoxy first. That should be enough, and arcovers aren't too bad now - the last failure in the 2nd photo was merely a fluke. It arced to an an area with no coating and i just kept forcing it to fail for the photo-op.
Blackplasma,
I accidentally had very high compression enabled when i resized the first photo, so thats why it looks like garbage.
Here are some new photos including two inside the box, and another arc photo which is a composite of two photos (two break-out points too)
1149249398 15 FT10626 Drsstc03 Internal01
1149249398 15 FT10626 Drsstc03 Internal02
1149249398 15 FT10626 Drsstc3 01
Sat Jun 03 2006, 01:14AM
Very nice inside! Is the heatsink just a thick plate of aluminum?
Looks like you dont even need the strike rail suprised . I try not to allow too many primary hits, though the few that ive had, havent been a problem. You certainly are testing its resiliance to primary strikes, thats great!
Sat Jun 03 2006, 02:30AM
Thanks.
The heatsink is an actual extruded heatsink with fins. The fins are underneath and in the airflow of the fan.
Dan
