  • Guests: 27
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Lateral Induction Launcher
Sat Jun 03 2006, 05:57PM
couldn't you use some fiberglass cloth? They sell the woven kind in the autobody department of autoshops and home improvment stores... Seems like a layer or 2 of that on both sides shoud hold up pretty well...
Maz
Sat Jun 03 2006, 07:51PM
Maz Registered Member #111 Joined: Fri Feb 10 2006, 01:04AM
I can see fiberglass flexing just as much if not more than mdf. the only thing I can think of for this to work is like 1" thick polycarb with space machined out for the coils. Could you add a steel or iron plate to the outside of the coils, so that it may condense the flux to the interior?
Electroholic
Sun Jun 04 2006, 02:08AM
How about this, make the coils a lil bigger(dia), use steel plates between the coils(might want to slot them), then put a piece of U shape support in it on the edge. as long as the the support dont' concentrate the flux, it should shoot fine.
Might loose eff. due to poor coupling tho...
FastMHz
Wed Jun 07 2006, 08:18PM
Well here's a pic of the destroyed coil...it deformed or I'd just glue the coils back down to the wood:
1149711511 179 FT10474 Brokencoil
Wilson
Thu Jun 08 2006, 06:28AM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
What about weaving the coils through some fibreglass cloth and then impregnating the whole thing with lots of CA glue?
Electroholic
Thu Jun 08 2006, 02:54PM
CA glue need OH- to dry/harden....blahblahblah
so a big chunk won't harden like resin/2part epoxy.
FastMHz
Thu Jun 08 2006, 05:39PM
I like the fiberglass idea...since I'm already using epoxy it wouldn't be a big change and would probably add a lot of strength...now where can I get some? Home Depot doesn't have any, though they did at one time.
Electroholic
Thu Jun 08 2006, 08:19PM
try body shops, CAR body shops.
there are hobby shops online selling all kinds of fibers,
even kevlar.
