Registered Member #2431
Measure +100Mohms, is it possible to increase....the normal range from 40M to measure very high ohm resistorslike 200M? i vaguely remember a thead where this may have been mentioned, but for the life of me i cant find it. is this possible or am i mistaken?
Registered Member #2893
You could try sending 10kV through the resistor and then measure the current that comes out. Then use ohm's law. 10kV though a 100M resistor would give you 0.0001A.
Other than that I can't think of a ay to measure such a high resistance.
Registered Member #1938
I believe it is possible to use a known impedance multimeter, a known regulated DC supply (10V) and the big ohmic resistor.
Connect the DMM in series with the resistor to be measured, and read the voltage (you might need to set the scale to milivolts).
Assuming R1 is to be determined, and you know R2 - the resistance=impedance of your multimeter in DC, Vin is the known DC supply voltage, and Vout is what you read on your Multimeter, R1 would be:
R1= ((Vin - Vout) / Vout) * R2
This will work for sure, I did some measurements using this already.
Registered Member #2099
As others have said, you either need more voltage or sensitivity to lower currents.
Ordinary digital multimeters measure resistance using "force current, measure voltage" mode, so extending the range is nontrivial. You could measure a 39M resistor, barely within the range of your DMM, then put the unknown resistor in parallel and measure the combined resistance.
Classic "meggers" have a hand-cranked dynamo to generate test voltages of 500 volts or more. Then even multi-giga-ohm leakage paths conduct enough current to be accurately measured with robust electromechanical meters.
But for most of a century it's been possible to generate the HV with batteries & switching converters.
Registered Member #1408
I've owned one of the Meggars and IF you can find them used; they drop in price substantially. The hand-crank is not made for any long term use (not that robustly made). But they ARE available at substantially less if you don't buy them new. Often contractor's supply places (if they have used materials) will have a few. I also have a source for very high resistance HV ceramic resistors at a good price. If you have any interest, PM me. I believe 100Mohm are available (around $30). They're not small (12' by 2", heavy screw connections).
Registered Member #162
How accurately do you need to measure the resistance?
What kind of meters do you have and what's their accuracy?
Meanwhile, you could get a string of resistors to add up to 100.0 MOhm, the precision of each resistor as good as or better than the required accuracy. e.g. a pack of ten x 10 M 1% = $1
This will enable you to use inaccurate/uncalibrated instruments to check your resistor using whichever method you choose.
I'd go for 'apply a high voltage and measure the current' approach.
P.S. I'm surprised how many uses 'pracision' resistor strings find in my shed, worth keeping.
