  • Guests: 41
buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
PIC Interrupter Program
EDY19
Fri May 26 2006, 12:37AM
Yup, that is exactly what i am looking for, Anders! What chip is it for? Just any PIC? I was thinking the 16F628, did that one have a display as well?
Wolfram
Fri May 26 2006, 01:00AM
It should work for any PIC12/PIC16.
He wrote three routines, but only one of them seems suitable for this, he gave me permission to post it.
As it stands now minimum on-time is 18µS, adjustable in 3µS steps, max 10s when running the PIC at 4MHz. The same applies to the off-time.
wloop	bsf	PORTB,1
	movfw	on1
	movwf	t1
	movfw	on2
	movwf	t2
	movfw	on3
	movwf	t3
	goto	wl1
wl1	decfsz	t1
	goto	wl1
	nop
	decfsz	t2
	goto	wl1
	nop
	decfsz	t3
	goto	wl1
	nop
	bcf	PORTB,1
	movfw	off1
	movwf	t1
	movfw	off2
	movwf	t2
	movfw	off3
	movwf	t3
wl2	decfsz	t1
	goto	wl2
	nop
	decfsz	t2
	goto	wl2
	nop
	decfsz	t3
	goto	wl2
	nop
	goto	wloop
The program was written by Bjørn Bæverfjord.
EDY19
Fri May 26 2006, 12:26PM
So the output would be on pin 7 on a 16F628, correct? That pin is labeled RB1. Also, I plan on changing the oscillator to 16MHz, so what values would I have to change for the timing, and multiply them by 4 to get the same time, right? Lastly, what compiler/programmers do you use? Thanks for all the help, this is my first programming project ever smile And it would be nice if it worked correctly.
Wolfram
Fri May 26 2006, 01:56PM
As of now, this is just the code to do the timing. Running it at 12MHz would let you control it in steps of 1µS, with the lowest on-time as 6µS. 6µS is quite a bit when it comes to DRSSTC stuff, so I guess the code would have to be modified to allow lower minimum on-time to be good for DRSSTC stuff.
EDY19
Fri May 26 2006, 10:24PM
Well, looking at steve wards site
the burst length goes from 60uS up to 200uS at 120bps, so I don't see how 6 would be a problem. Is 120bps the same as 120 Hz?
Fri May 26 2006, 10:33PM
I designed a DRSSTC interrupter circuit with two 555s (or a 556) like what Avalanche suggested. One pot adjusts the frequency from "Single shot" up to 200Hz and the other adjusts the on-time from 5 to 300us. When the frequency pot is turned to "Single shot", pressing the button triggers a single pulse.
Both pots are linear, so you could use 10-turn pots with counter dials and read the frequency and on-time directly. The op-amp is really just there to make the frequency pot linear.
I've also made an interrupter driven by a PIC, but I decided the analog circuit above was less hassle. It took about a day to design, build and get working. The PIC interrupter was a fancy unit that made clumps of up to 64 pulses with pseudo-random delays between them, the idea being to produce a big fat spark from an old SSTC design that couldn't do anything too impressive with just one pulse.
Yes 120bps is the same as 120Hz.
EDY19
Fri May 26 2006, 11:11PM
I think that the easiest way for the actual signal is by far the 556 timer. Thats what I think I'll go with just for the sake of not bothering so many people about coding the PIC. But, I still have to make the display, thats one of the requirements for me. Steve, you don't happen to have a PCB file for that 556 or 555 thing, do you? It should be a great thing to have around as a oscillator for lots of different projects, as well. So drop the PIC oscillator thing, I think I will just use it as a display. I found a site
which has a program labeled weedfreq8x2LCD
which is a frequency counter with an output for a LCD display (8x2) I would like to change this to a 16x2 display though as well as adding on and off times. Hints are greatly appreciated!
When you say "interrupter output active low," does that mean that when the driver is low, that corresponds to the on time? Lastly, I want to cut out the single shot switch from the 556 timer portion and add it to the PIC circuit, there will be a switch to switch modes between single shot and oscillator. In order to do this, I can pretty much just take out the whole IC3A section, and connect the reset of the 555 to Vcc, right?
Sorry for all the questions but i want this project to turn out right! wink
Sat May 27 2006, 02:30PM
Hi edy
If you're wanting an LCD readout, I would say it actually becomes easier to do the whole thing digitally in a PIC. I designed my circuit so you could use 10-turn pots with counter dials to get a mechanical readout. If you do bolt a PIC onto an analog pulse generator, you have to deal with problems like:
How do you read the pulse width accurately?
How can you update the display when the fire button isn't pressed (and hence the oscillator is doing nothing)
I also did a PIC interrupter that uses a DDS algorithm to give breakrates from 0 to 1000bps, but I ended up building the analog one because I couldn't be bothered coding a user interface for it.
Yes, the output is high all the time and goes LOW to fire the burst.
No, there is no PCB. It took me less time to slap it together on a piece of stripboard than it would to lay it out in Eagle. Of course I'm not stopping any of you guys designing one if you want to. tongue
The switch isn't a single shot/repetitive select switch, it's a fire button. The unit only gives pulses while the button is pushed in. If you push it while the breakrate pot is turned all the way down, you only get one pulse per push of the button. I don't know how you would adapt that to a PIC. You are right that you wouldn't need IC3A: it's only there to debounce the switch.
1148740227 30 FT10039 Img 1465 Small
Wolfram
Sat May 27 2006, 02:46PM
Steve, would you mind sharing the code you wrote? I might have the time to code an interface for it.
EDY19
Sat May 27 2006, 04:22PM
Second thoughts, maybe using the PIC all the way would be easier display wise as well as the single shot and oscillator interface. I was thinking a rotary encoder (say 24 switches per rotation) would be good, as this keeps the information digital instead of using potentiometers. For every 15 degrees the switch is rotated (one pulse) the frequency could jump by 5Hz and the duration of the pulse from 10uS-300uS, with a second mode for single shot or a switch or something. I think this would be easier than using the 555s and the potentiometers for getting the frequency and on/off time displayed.
edit: Trying to think how a rotary encoder can "think" it is going forwards or backwards-wait, i dont think that it can tell tongue . Looks like we may have to go with a potentiometer and an analog to digital converter- darn, more programming...
Edit: Moved to computer science considering it has more to do with programming now
