  • Guests: 21
Desmogod (48)
Alex Smith (31)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
Idea: harmonically driven TC
Crunchy Frog
Tue Aug 24 2010, 04:11AM Print
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
So I had a thought. What if one were to drive a TC with the primary resonating at half (or maybe less) the secondary's Fres? I ran across this accidentally in a simulation, and it seems to work in the simulator, so why not in real life?
This would seem to help with (for example) headaches getting IGBTs to switch at high frequencies.
I don't have a setup to test this on, but maybe someone else here does.
radiotech
Tue Aug 24 2010, 04:49AM
TV flybacks have been doing this for years ,driven at 15734 Hz and resonating at the 3rd harmonic and later the 5th harmonic.
The makers are very particular in the winding design and there is considerable difference between solid state TV's and the tube ones.
teravolt
Tue Aug 24 2010, 04:51AM
you could do this but the pulse width would have to be equal to 1/2 cycle so your tesla f=200khz then your pulse width is 5us. A igbt can do about 100khzs max so your wave form would be 100khz or a multipul of 200khz with a 5us pulse width. does this make sense
radiotech
Tue Aug 24 2010, 06:23AM
Crunchy Frog wrote "I ran across this accidentally in a simulation, and it seems to work in the simulator,"
Did your simulation allow changing the coefficient of coupling?
That image in reply to Dingo 27's thread gives some math on the effect of coupling governing which 2 frequencies will be present in both the primary and secondary of a drtc. Also EastVoltResearch mentioned the effect of the arc's capacity changing fres.
"I don't have a setup to test this on, but maybe someone else here does. "
Of course a spectrum analyser would be nice but a simple investigation can be done with the most simple tool-a wavemeter which consists of a variable condenser, from an AM radio and an inductance to resonate around 200-400 kHz , perhaps 300 uHy. A dmm connected to a diode tap on the coil will indicate resonance and the dial of the variable cap can be marked off in frequency.
Tue Aug 24 2010, 08:47AM
I think it would only work at f0/3, f0/5 etc. because a square wave has odd harmonics. This would probably work better for a DRsstc, because in a SSTC the primary current would ramp up to a huge value because of the primary's low inductance.
Hazmatt_(The Underdog)
Wed Aug 25 2010, 02:15AM
Actually, the odd part is the secondary will ring up when the primary is at 2/3 Fo. I was doing some sweeps with my power amps and noticed this, but I can't account for it just yet in simulation, and I need to rebuild my poweramp. I may post more on that later, I dunno, it's hard to do this stuff and work full time.
radiotech
Wed Aug 25 2010, 03:05AM
Hazmatt the Underdog wrote: Actually, the odd part is the secondary will ring up when the primary is at 2/3 Fo.
Yes but that usually sparks up (sic) a furious debate about whether or not subharmonics do in fact exist.
Coronafix
Sun Aug 29 2010, 12:03AM
It's called a Perfect Fifth in music! i don't see what the debate could possibly be about.
dex
Sun Aug 29 2010, 05:36PM
dex Registered Member #2566 Joined: Wed Dec 23 2009, 05:52PM
radiotech wrote ...
I've heard only of higher harmonics (from Fourier analysis).Would you be kind to define and specify meaning of "subharmonics"? I've done some PSPICE simul for DRSSTC excited by 2/3 Fo of secondary natural frequency, with typical coupling of 0.15.All I can see from it is that the power transfer is poor in comparison with Fo excitation...
mistrust
radiotech
Sun Aug 29 2010, 07:21PM
The debate centers around the fundamental. If a harmonic is a higher multiple of the fundamental then subharmonics are just an as yet not undiscovered fundamental. In Helmholtz, (Sensations of Tone), he states the G S Ohm was the first to declare that there is no form of vibration that will give rise to no harmonic upper partial tones,and therefore will consist soley of the prime tone.
The electrical cases are found in apparent subharmonics in non-linearalities especially in AC ferrite magnetizations. Hence Hazmatt's comment, which is valid in that they do appear. Squedging is common is a lot of stuff, especially oscilators. But he was driving the flyback with something that made it produce multiple signals. his conclusion 3/5 Fo was based on the fact that this was 3/5 of what is ' should' have ringing at. The key word in his send was the word coupling because that is the variable known since spark transmitters
of adjustable to regulate multiple modes.
Back to Hemholtz. .. this a form of vibration pecular to pendulums and tuning forks.. we will call these pendular vibrations, or since they cannot be be analysed into a compound of different tones, simple vibrations.
Helmholtz used an early oscilloscope A smoked drum onto which a stylus made a mark as it rotated.
