Donate: 4hv.org is hosted on a dedicated server. Unfortunately, this server costs and we rely on the help of site members to keep 4hv.org running. Please consider donating. We will place your name on the thanks list and you'll be helping to keep 4hv.org alive and free for everyone. Members whose names appear in bold have donated within the last three months.
Special Thanks To:- Aaron Holmes
- Aaron Wheeler
- Adam Horden
- Andre
- asabase
- Austin Weil
- barney
- Bert Hickman
- Bill Kukowski
- Brandon Paradelas
- Bruce Bowling
- Cesiumsponge
- Chris F.
- Chris Hooper
- Corey Worthington
- Derek Woodroffe
- Dalus
- Dan Strother
- Daniel Uhrenholt
- Dave Billington
- Dave Marshall
- David F.
- Dennis Rogers
- drelectrix
- Dr. John Gudenas
- Dr. Spark
- eastvoltresearch
- Eirik Taylor
- Finn Hammer
- Firebug24k
- GalliumMan
- Gary Peterson
- George Slade
- Grant
- GreySoul
- Henry H
- IamSmooth
- In memory of Leo Powning
- Jacob Cash
- James Howells
- James Pawson
- Jeff Greenfield
- Jesse Frost
- Jim Mitchell
- John Forcina
- John Oberg
- John Willcutt
- Jon Newcomb
- Leslie Wright
- Lutz Hoffman
- Mads Barnkob
- Matt Gibson
- Matthew Guidry
- Michael D'Angelo
- Mikkel
- mileswaldron
- Neil Foster
- Nick de Smith
- Norman Stanley
- Patrick Coleman
- Paul Brodie
- Paul Jordan
- Paul Montgomery
- Ped
- Peter Krogen
- Peter Terren
- Richard Feldman
- Robert Bush
- Royce Bailey
- Scott Fusare
- Stella
- Steven Busic
- Steve Conner
- Steve Ward
- Sulaiman
- Thomas Coyle
- Thomas A. Wallace
- Torch
- Ulf Jonsson
- Vaxian
- William Kim
- William N.
- William Stehl
- Wesley Venis
The aforementioned have contributed financially to the continuing triumph of 4hv.org. They are deserving of my most heartfelt thanks. |
Spooky Cornstarch
| Tesladownunder |
Sun May 07 2006, 08:43AM |
Joined: Thu Feb 02 2006, 03:45AM Location: Bunbury, Australia Posts: 1345
Inspired by a recent video I decided to do make my own cornstarch fun. Essentially cornstarch liquid is a fluid whose viscosity is flow rate dependent. You can hit it hard with a spoon and it will strike it and bounce off, but can be poured slowly and drip from a spoon like a thin liquid. A real anti splash fluid. On a flat plate under vibration the vibration is probably more marked at discontinuities and edges (like a wave breaks at the seashore). This leads to strange effects with cornflour which gets forced up into stalagmites, loops and bizarre slowly moving spooky shapes like pools of writhing undead...
Anyway it is very easy to do. Get the wife/girlfriend/significant other to make a reasonably thick cornflour/cornstarch mixture. (This is a common cooking ingredient). Get a 4 inch loud speaker (I used 4 inch, 4 ohm, 3.5W) and feed it with 50Hz/60Hhz. Use a 6VAC winding with a dropping resistor or use a variac. I needed about 2.0 VAC ie 1W. Place some plastic cling film (Gladwrap in Australia) loosely over the speaker so that a spoonfull or two of the cornstarch mix will sit closely applied to the speaker cone.
I did try a frequency generator and different frequencies but 50 Hz seems fine, particularly as it dries a little and the viscosity rises.
Here is a sequence of still pics as the power increases.
Peter
..... "Power tends to corrupt, and absolute power corrupts absolutely." Lord Acton, 1887. ...................... See absolute corruption at  |
| Back to top |
| Blackplasma |
Sun May 07 2006, 09:30AM |
Registered Member #63 Joined: Thu Feb 09 2006, 12:18AM Location: Posts: 1417
That's.. um.. filthy, TDU =-D
You never cease to amaze me! :)
Keep up the great work. |
| Back to top |
| Nik |
Sun May 07 2006, 04:22PM |
Registered Member #53 Joined: Wed Feb 08 2006, 10:31PM Location: Ontario, Canada Posts: 439
So I saw this and it was too simple no to try. I blew out the first speaker (it wasn't really a robust looking unit). I managed to get good results (posted here ) useing a 10w speaker drivin at 50hz and 101hz (that causes the beating). The I seemed to get the best "fingers" between 48hz and 62hz, out side of that I needed to increase the amplitude.
I also experimented with diffrent wave forms. Sin gave the best results, square did not form fingers (the speaker could not have handled the power), triangle took a higher amplitude then the sin but did produce fingers, sawtooth caused the cornstarch to splash out before fingers formed.
I may pick up a speaker that can handle a higher power and continue these experiments. If all goes well I might have a post for the projects forum.
*edit* NSFW ads on the link
Phd in Drinkometry and .0174 radians in math. |
| Back to top |
| Tesladownunder |
Sun May 07 2006, 07:46PM |
You must have been using a bit of power to blow the speaker since you can get pretty good cone excursion with the 1W I was using (amended figure). Sine wave is best since the low frequencies are what works and the higher harmonics with any other shape dont seem to help and probably tend to break the coupling. I didn't have any other loose speakers readily available as I had blown them up with my capacitor bank in the name of science
You may get better results as the cornflour thickens as it dries a bit and doesn't flow as well.
I will repeat this and try for a video later. I suspect that there will be a bit of blurring though due to the vibration and that a flash camera shot does capture things more sharply.
Peter
| Back to top |
| Nik |
Sun May 07 2006, 07:52PM |
The cone in my speaker(s) arepretty steep so it takes alot more power to vibrate the whole volume of the liquid. The speaker was free from the side of the road so I don't know if it was previously damaged. The coil is fried (crunches and reads 0 ohms).
| Back to top |
| Alex |
Sun May 07 2006, 08:54PM |
Geometrically Frustrated
 Joined: Wed Feb 01 2006, 10:18PM Location: Bowdoin, Maine Posts: 407
Wow, that was a very neat video. It's like waves crashing on the beach, but they don't break.
The last picture posted is particularly interesting because you can see a definate break in one of the loops.
Object Manipulation is doing things with stuff. |
| Back to top |
| Heiders |
Sun May 07 2006, 10:48PM |
Registered Member #268 Joined: Mon Feb 27 2006, 08:44PM Location: Ontario, Canada Posts: 48
It's also really cool when a drop of food colouring is added at different frequencies. You would expect it to spread out evenly, but it actually tends to stay on one side. The cornstarch is drawn up from the middle and dropped on the outside. Then more is dropped on top with the next wave, pushing the original stuff to the bottom while carrying the food colour, and keeps cycling on each "side", as it were.
(I was at Nick's house this afternoon during the experiment )
TDU wrote ... pools of writhing undead Undead indeed!
If virtue can't be mine alone, At least my faults will be mine own. |
| Back to top |
| Nik |
Thu May 11 2006, 09:25PM |
I picked up a 10inch 100w speaker for 20$ cad to further my experiments with cornstarch. I have a photo to post tonight and i will write up some more tomorro.
| Back to top |
| Tesladownunder |
Fri May 12 2006, 12:12PM |
I did a physics demo today for the opening of the Cosmology gallery at the Gravity Discovery Centre near Perth, Western Australia and showed some 80kV sparks, aerogel, magneforming, ferrofluid and the cornstarch demo. I had less than a days notice so it was rather hastily put together.
And the audience response? The ladies have all used corn starch and were fascinated by it, Small kids preferred the ferrofluid. Real men preferred the HV.... Science teachers liked the simplicity of the cornstarch.
Had to remake the cornstarch after about 1 hour, but it got a lot of use. As it got thicker it tried to escape by forming a ball and nearly jumping out.
No pics of the cornstarch as too busy doing the demos and the lighting wasn't good. Must make a video sometime.
Peter
| Back to top |
| Tesladownunder |
Sun Oct 08 2006, 09:18AM |
I tried this with a subwoofer and the results were a bit disappointing initially.
Photo 1 shows the 12 inch subwoofer driven with 40 W at 50 Hz (12 VAC). Removing the plastic and putting the cornflour directly on the speaker improved things only a little. I later tried higher with perhaps 200 W but not much better. Photo 2 Shows the setup with a frequency generator and a 100 W audio amp. I picked out the resonant frequency of about 22 Hz where cone excursion was greatest and up to one inch. then things started to move. Photo 3 shows a blob in flight Photo 4 shows a close up. Spooky
I guess I got lucky with a 50Hz resonance with the little speaker which in some respects was still the more dramatic demo and the smaller excursion makes things more visible.
Peter
| Back to top |
| Avalanche |
Sun Oct 08 2006, 10:03AM |
Registered Member #103 Joined: Thu Feb 09 2006, 02:16PM Location: Derby, UK Posts: 625
I'm going to have to get out my subwoofer and try this again sometime, that's if I didn't kill it last time. I was also driving it at about 200 watts, but only about 5Hz (I didn't quite do it right). It seems to be waterproof as well, so I can just pour the stuff right in...
"I've lost track of where all the different burning smells are coming from..." "Is the water off? I need to cut this hose" ... "That's not a hose you idiot, that's the 3-phase!"
| Back to top |
| EastVoltResearch |
Sun Oct 08 2006, 10:52AM |
Joined: Thu Feb 02 2006, 07:11AM Location: Philadelphia, PA Posts: 2408
And my friends always told *me* i had too much time on my hands . . .
DRSSTC, SSTC, HV Educational Kits and Parts http://www.easternvoltageresearch.com Be sure to check out our student sponsorship program! |
| Back to top |
| Avalanche |
Sun Oct 08 2006, 11:28AM |
should I be worried?
| Back to top |
Moderators: Chris Russell, Noelle, kalenedrael, Alex, Grant, Tesladownunder, ShawnHV, EastVoltResearch, Dave Marshall, Ben, Bjørn, Matt, Dave Billington, WaveRider, Steve McConner, Anders M., Simon, Tim Koene
