Registered Member #91
I've been working on an improved version of my SSTC for quite some time and today it was finally time to power it up for the first time.
My previous SSTC was almost entirely based on Steve Ward's mini SSTC. It worked, but not especially well and the MOSFETs exploded on a regular basis. So for this new coil I ditched everything but the secondary coil and started again from scratch.
The first thing I made was a remote control box which also contains an interrupter. The interrupter is a simple 555 design. The on- and off-times can be controlled by using two potentiometers. There is also a knob to select one of six possible interrupter modes, each resulting in its own particular spark appearance. The box connects to the SSTC controller through a shielded 8-core data cable (of which only 4 wires are used, but I could get the shielded 9-pin D-SUB connectors for much less than shielded 4-pin connectors...). There is also room reserved for an audio interrupter, but I haven't made one yet. The small "on/off" switch doesn't have a function yet.
Then it's on to the power electronics. I made a wooden base on which everyting is mounted in place.
The coil is powered by a full bridge with four IRFP-460's. It is controlled by a version of Steve Ward's improved PLL driver. The driver is housed in the aluminium box with the fan (the fan blows directly on the gate driver chips). The relays switch the power to the bridge and are controlled by the "PWR" button on the control box.
The complete setup looks like this:
I believe the toroid is a bit oversized for this little secondary coil, but unfortunately I couldn't find aluminium ducting with a diameter less than 10 cm. With this topload, the resonant frequency is about 220 kHz. I aimed for 250 - 300 kHz, so I guess it's acceptable.
This is at 120 V AC input. My ultimate goal is to go all the way up to 230 V, but at about 150 V input the coil starts to stutter. I guess this is due to the feedback signal getting messed up. Also, I fear I need more turns on the primary to keep the bridge (or my fuses...) from blowing at the full input voltage.
So far I'm pretty pleased with the results. This coil is already much more impressive than my previous one and there is still room for improvement. One thing bugs me though: I haven't been ably to get current transformer feedback working. Currently the coil runs fine with antenna feedback but I would like to switch to a CT instead as I believe that may solve the "stuttering" problem at higher input voltages. My current CT has a 1:60 ratio. Unfortunately the PLL doesn't lock to the resonant frequency when I connect it (reversing the phasing makes no difference). Any suggestions will be appreciated.
Registered Member #1403
I like your style, its similar to how I have built SSTCs.
I was just wondering about the little piece of test pcb that you have two relays on, are the tracks underneath wide enough to handle lets say 3500W in CW mode? I could easily pull 2500W in CW mode with my similar coil.
wrote ...
Well, I have to admit I took some inspiration from your Kaizer SSTC's.
wrote ...
I made the connections with solid copper wire meant for mains wiring, so I'm confident it can handle the power. I have to say though, that I underestimated the power levels a bit as I expected something like 1,5 kW at 100% input voltage.
This is what's inside those metal boxes:
I also tried snapping a picture of the bridge, which was difficult because it's mounted upside down.
Today, I got the CT feedback working. It turned out that it was a phasing issue after all. With the CT the coil works a little better than with the antenna.
However, I also had a bit of a setback. I was gradually increasing the power level. However, somewhere around 70% of the maximum input voltage the coil consistently stopped working and started producing a suspicious sound. I could not see anything going wrong though, so I kept running the coil at the point were it still worked OK (about 68% input voltage) and pushed the power levels up by adjusting the interrupter settings. Suddenly however, the toroid started smoking. I immediately shut everything down and after taking apart the secondary coil and toroid this is what I found:
It seems that the toroid got so hot that it started burning the PVC at the top of the secondary. Also, the glue I used on the toroid to attach pieces of aluminium foil (to make the point were the toroid is joined together look less of a mess...) melted. This caused an awful mess as you can see.
Is it normal that a toroid gets so hot that it can burn the PVC? Also, I think the coil crapping out at 70% input voltage may confirm my fear that this secondary really is too small to handle more than, say, 1 kW. What do you guys think?
I've given the failure some thought and there appeared to be internal arcover. This is probably also why the output suddenly disappeared: the voltage got so high that the preferred discharge path became something on the inside of my secondary instead of the air.
All this left a burned discharge path at the inside of the secondary. Fortunately, it looks like it didn't go entirely through so the wire is still undamaged and I can Dremel the charred track away.
What I'm going to do next (in a week or two):
- Repair the secondary - Mount the toroid in such a way that internal arcover is less likely (and also in such a way that I can actually see what's arcing to what) - Replace the glue on the toroid with something more heat resistant - Try again and hope it doesn't fail
Yesterday, I spent the whole day making a new toroid mounting (placing the toroid higher) and completing the base.
Here's a pic:
I managed to drop the toroid on two occasions yesterday, which is why it looks all messed up.
There is, however, a problem. When I still had the coil sitting next to the base, everything worked perfectly. With the new toroid mounting, the sparks were better than last time and toroid heating was considerabely less.
Now that I have mounted the coil on top of the base it only works for maybe 10 seconds and then stops. The only way to get it going again is to turn off the input voltage and wait until the voltage on the bridge has gone down to zero.
I'll have to investigate the cause of this. Right now, I'm thinking its some kind of interference issue.
