Registered Member #190
Well, the good news is I have gotten a 1/4" nut to glow bright orange for several minutes without overheating my mosfets. I seem, though, to have hit a wall in getting it hotter.
My unit is a half-bridge using 170vdc as the power input. The design is similar to except the inverter output goes to a 20 turn step-down transformer which encircles one of the legs of my LC series tank. The work coil is 2" diameter 3/8" copper pipe with 5 turns. The capacitor is a bank for a total of 1.0uf.
I tune the resonance manually with a pot. I find that right at resonance it flips back and forth, and I have to adjust the pot to stay there, especially if I am near 170v input. My work coil is attached to one side of the capacitor bank, so the capacitors don't share the current equally, but they don't get too hot. I don't know if this is a big deal.
Would heating the nut in a crucible instead of open air help? where can I get one? Would adding a PLL help, or should manual tuning work well enough? Would decreasing the turns on the step-down transformer allow me to get more current into the tank?
Registered Member #540
I think you can't get it hotter because you reached the curie point making the nut no longer magnetic. I don't know how much a crucible would help you once you reached the curie point. I'd think it wouldn't do much because it will have trouble getting above the point where it's no longer magnetic.
I should have said "It gets a lot harder to heat it hotter than curie point because you don't have hysteresis losses anymore". I think you would have to heat it up hotter with resistive losses after the curie point. I'm not completely sure though.
Registered Member #2310
Hi Iam, i was trying to build a IH too, and then i finally got mine to work, with danyk's schematic works pretty nice i like to tune it manually, is a way of getting entertainment while watching the screw becoming white...if you like this too, you'll probably like to try this circuit....the IGBT's used are not with anti-paralel diodes inside, so if you can get acess to some diode protected IGBT, you can get rid of the Turbo diode drawed..
Registered Member #1223
I would say you will need at least 1kW of power to melt some small steel/iron pieces. My induction heater is limited to 3kW wall outlet so far and it can melt some 10mm thick steelbars @ 10A/230V input.
However, we need actually lots of circulating reactive power.
Registered Member #2494
Hello all.
Tonskulus i want to ask You a question. I want to modify my circuit to work with 220VAC so this will be 310 to 350VDC I use IRFP460 mosfet transistors. And now all is working perfect with 154VDC so i have almost 400VAC on "work coil" And i think if i will use 310VDC i can have max from 974VAC to 1099VAC on work coil.
So do i need to have mosfets minimum 550V / 600V ? or more ? IGBT 1200V ?
Can You tell me what i need also to change - because i want to know more before i "blow" some mosfets :)
Very nice.
What was that sound at the end? Water boiling in the coils? Are you using a coiling fan for the chips?
If you get the workpiece any hotter you are going to have molten metal (2400F melts, 5400F boils) falling on your platform. I would have some type of crucible with a water bath below the coil to catch the molten metal.
