  • Guests: 28
Desmogod (48)
Alex Smith (31)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
Kaizer DRSSTC I
1 2 3 4  last
Thu Sept 17 2009, 08:24PM Print
It have been a long time since I first saw a DRSSTC in action and immediately fell in love, but knowing damn well I at that point was in no state to build one, or simply just understand it works.
Many moons have passed, many threads and fewer books have been read, hopefully it will have paid off to wait with building one till I felt it was time :)
Greatest inspiration for this coil must be Steve Wards DRSSTC-1
updated: 6th November 2010
Specifications
Resonant frequency
Around 70 KHz
Secondary
160 mm diameter x 605 mm height , 2200 turns of 0.25 mm enamelled wire
Topload
630 diameter x 130 mm ducting diameter, dryer ducting, this is subject to change
Primary
320 mm diameter x 150 mm height, 9 turns of 10 mm copper piping ~ 28,27 mm^2, tapped at 5.5
Bridge
Fullbridge of IXGN60N60C2D1 IGBTs, SOT-227 package
150 mm length x 80 mm width x 90 mm height, 1 KG of heatsink
2 x 3300uF 450V BHC capacitors for 6600uF bridge filtering. (each: ESR 39mOhm@100Hz, Z 27mOhm@10kHz and 53A Iripple@70KHz@50 Degrees celcius)
MMC
6 Strings of 2, 942C20P15K-F
0.45 uF rated 4000 V and 81 A Irms
Timeline
20th March 2009
Bought 30x IXGN60N60C2D1 from digikey usa, import taxes etc almost killed me
7th April 2009
Bought 60x 942C20P15K-F capacitors through dr.spark, again hello import taxes
15th May 2009
Bought heatsinks cheap from germany
19th May 2009
Started converting Wards latest drsstc driver to single sided board
23rd July 2009
Started 3D designing the fullbridge
It is bulky, on 2 heatsinks with capacitors between them, its too big and needs to be overhauled.
23rd August 2009
Redesigned the fullbridge
The two IGBTs in the middle are turned 180 degrees to have the supply at one side of the heatsink and output on the other, it got compact, neat and only one overlap with busbar, I am very happy with this design.
1253218586 1403 FT1630 Bridge1 1
24th August 2009
Made a spreadsheet to ease experimenting with different DRSSTC settings, this was also a try to collect some of the different theory and put it side by side, it might not all make sense
1253218586 1403 FT1630 Spreadsheet1 0
27th August 2009
Bought 50 meter of 10 mm copper tubing, two drain pipes 160 mm diameter x 1000 mm and 1,5 mm copper sheet.
Also in the picture there is worth noticing the current transformers harvested from industrial Siemens overcurrent protectors, they are for 690VAC 200A, but might be useful at higher frequencies, this will show later on, they do look like 1000 turn.
1253218586 1403 FT1630 Img 2665
8th September 2009
Finished converting Wards latest drsstc driver to single sided board
12nd September 2009
Finished assembling the single side board ward drsstc driver
1253361635 1403 FT1630 Img 2679
1253361635 1403 FT1630 Img 2680
16th September 2009
Etched, assembled, tested and housed interrupter with burst mode
1253361635 1403 FT1630 Img 2672
1253361635 1403 FT1630 Img 2678
19th September 2009
Cut out busbar from copper sheet and assembled IGBTs, heatsink, capacitors with busbar, home made 8mm brass spacers are used. Leads to the primary are 16mm^2 stranded 90 Degree celcius machine tool wire.
1253361635 1403 FT1630 Img 2673
1253361635 1403 FT1630 Img 2674
1253361635 1403 FT1630 Img 2675
25th September 2009
Found a aluminum box and transformer for the driver, wound a GDT and started preparing decoupling capacitors, TVS and zeners for the bridge.
1255545675 1403 FT1630 Img 2688
1255545675 1403 FT1630 Img 2691
With all the wonderful theory about GDTs in the wiki, it would be a shame not to check it out instead of just going for a high permeability core with 10 turns on CAT5 cable. So here goes
1255545675 1403 FT1630 Img 2683
Its a Epcos ringcore, material: N30, good up to 5MHz, Aemm^2: 95,89, AL: 5750nH
Inductance with 10 turns: L = AL * N^2 = 5750 * 10^2 = 575 uH
Peak current: Ipeak = (Vin * t * D) / Lmag = (24 * (70000/1000000) * 0,5) / (575 * 10^-6) = 1460 mA
Irms = Ipeak * 0,577 = 842 mA
Minimum number of turns needed to avoid saturation
t, 50% duty cycle = (1 / 70000) / 2 = 7,3*10^-6
Nmin = ( V x t ) / ( B x Ae ) = (12 * (7,3*10^-6)) / (0,2 * (95,89*10^-6)) = 4,6 turns
Current needed to drive a single 60N60 IGBT gate
I = ( C * V ) / t = ((3,9*10^-6) * 24) / (7,3*10^-6) = 12,8 mA, including magnetising current, double this figure.
So it all seems to have overhead enough to drive a full bridge.
3rd October 2009
Started on contruction of the MMC
10th October 2009
Made the round platform plates for the coil to be built on, they were cut out from 19 mm MDF wood plates with a modified router, also shown in the picture, very neat for making circular cuts.
1255547369 1403 FT1630 Img 2229
11th October 2009
Finished MMC construction, features a 80 mm fan that delivers 30 cubicmeters/hour of air.
1255545675 1403 FT1630 Img 2684
1255545675 1403 FT1630 Img 2686
5th November 2009
Debugged PCB design of the driver Link2
Tested driver and interrupter on a small DRSSTC I put together just for testing purpose, blew the half bridge when I ran it in CW without feedback, I guess there is no way I could have treated that poor little coil any worse... suprised
12th December 2009
Made primary form and winded the primary coil onto it, with a strike rail and mounted on the upper platform, took me 1½ hours just to wind the coil through the holes and also spend quite some WD40 :D
The coil is a true helical coil with 4 mm steps between the supports
1260706669 1403 FT1630 Sdc10418
27th March 2010
It sucks to wind around half a secondary to learn that you used a ruler with 2 scales and you starter with 100 mm offset in the wrong direction...
1281219641 1403 FT1630 Img 0524
The second try on the secondary was winded in 2 hours using my new coil winder rig, its 2200 turns of 0,25 mm enamelled wire on a 160 mm diameter pipe, winding length is 605 mm, its currently hardening its second layer of varnish till I get time to visit my parents again as its staying at their garage while getting varnished.
1269880635 1403 FT1630 Img 0539
2nd August 2010
I made a fitting piece for holding the CTs as the cable shoes were too wide to go through the CTs
1281219641 1403 FT1630 Img 0892
1281219641 1403 FT1630 Img 0893
1281219641 1403 FT1630 Img 0894
7th August 2010
Today I assempled some of the parts on the platform, its beginning to look like a DRSSTC! Also I painted it black some weeks ago!
1281219641 1403 FT1630 Img 0897
1281219641 1403 FT1630 Img 0898
1281219641 1403 FT1630 Img 0899
1281219641 1403 FT1630 Img 0900
Its all wheels under the bridge...
1281219641 1403 FT1630 Img 0891
9th September 2010
The topload is done, measuring 130 x 620 mm, made from aluminium ducting on a wooden form, smoothed with filler for metal and covered in aluminium tape.
1284066300 1403 FT1630 Img 1379
17th October 2010
Final testing of driver features, got a 555 acting as a feedback at 70KHz while my signal generator is used to simulate over current input signal.
1287308843 1403 FT1630 Img 1870
1287308843 1403 FT1630 Img 1881
Test setup of the nopw ready to run coil! Still need some minor details before its finished :)
1287308843 1403 FT1630 Img 1884
FIRST LIGHT! YIPEE! Link2
5th November 2010
150 centimeter long sparks! Running from 250VAC in at 10A, 9 cycles ~200-225uS on-time, 500A limiter.
1289074645 1403 FT1630 Img 2669
1289074645 1403 FT1630 Img 2833
Video! Link2
brtaman
Thu Sept 17 2009, 08:28PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
Looking good Mads!
Looks like you have a lot of work ahead of you, can't wait to see your finished product! Your going to use the DRSSTC1 driver, correct?
Thu Sept 17 2009, 08:50PM
brtaman wrote ...
Looking good Mads!
The board you can see in the picture with materials is actually wards latest driver, further pictures, layout files etc will be posted once its debugged etc :)
Sat Sept 19 2009, 12:04PM
Updated thread with additional information and pictures of:
Bridge
Interrupter
Driver
Bennem
Sat Sept 19 2009, 07:24PM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Wow....some nice work!!
i think Steve got some 70-80 inch sparks from his DRSSTC-1 too!
look forward to more updates,
All the best,
Mel
Coronafix
Sun Sept 20 2009, 02:45AM
Always love your work Mads, nice bridge!
MRacerxdl
Mon Sept 21 2009, 12:17AM
Very good work! I cant wait to see some sparks from that coil!
Keep good working =)
Wed Oct 14 2009, 07:11PM
Updated the thread with further bridge work, GDT and MMC construction and the start of the platform.
brtaman
Fri Oct 16 2009, 09:59AM
Great bridge design, inductance kept at a minimum! How do you keep your copper looking so clean? Did you apply anything to it?
Killa-X
Fri Oct 16 2009, 07:04PM
brtaman wrote ...
I wondered the same thing...How do you do it? I know some people told me you could apply even a thin coating of varnish to it, clear varnish, to protect it...but this doesn't appear to be the case.
1 2 3 4  last
