Registered Member #1225
There is always the regular vttc, but you could perhaps put a small twist on it. Vacuum tube disruptive coil XD. 40 amps is really low for this though, soooo...
You could make a hf vttc, since it is a tetrode. You know, the 'plasma tweeter' circuit, secondary base fed and no primary.
A very ridiculous audio amp (yes this is a joke, unless you wanna be a bit different XD)
A low power induction heater.
A hf oscillator for assorted thing.
What would you use for power? A flyback is what i would use . Have fun, good luck!
I will most likely go with the Bipolar VTTC but will be open for ideas because it won't be soon when I will start that project.
Hmm break the tube and get the gold to sell it ?!? - I can make much more by selling the whole tube. And how can you break such a beauty ?!? This thing is staying with me, if not used - will go to a good friend of mine
Registered Member #30
I'd go for a disruptive DRVTTC for sure. 30 amps might not seem like much, but remember it's 30 amps at 33kV: 1 megawatt of pulse power.
Even allowing for some derating, as a disruptive coil burst is typically 150us, not 3, I'd still expect sparks over 3ft from it. Maybe only 1 or 2 per second on account of the 140W continuous plate rating.
See Mr. Conner has the right idea XD. Just use low tank capacitance. You could make a normal Dc resonant charging power supply, and use the tube as if it where a spark gap. I tend to think that might be easier on the tube, as it does not have to oscillate at such high freq, and you would use an anti-parallel diode to carry the oscillations on so that would only be half of the oscillations the tube has to conduct for. Then you can use a higher breakrate and stuff. It could use sidacs to trigger the tube at the right voltage. I was thinking something like the sidac's in series, when they break down they charge a small capacitor up, then some TVS's could let the cap only charge high enough. On the sidacs you would of course have a power resistor to keep tank cap from discharging through the sidacs. The capacitor could be adjusted to set on time, and it would have a bleeder across it.
You could also use a low freq oscillator and a half or full bridge, running a steup/isolation transformer tied to the grid. (gdt now equals GRID drive transformer :P)
Just ideas that for some reason i thought i should write down...
Now for the disruptive DRVTTC - I've been thinking on that for a long time and for it I have a much "better" tube than this one. A russian triode at 10kV plate, 1A continuous (130A pulse) and 4kW dissipation power on the plate. Hmm 2-3 burst in a secound sounds a "little too little". Any suggestions welcome
Registered Member #229
Nice looking tube. I have one also in my collection for a future project:
...but this will be only after I would finish the GU5B project. Unfortunately, I had not enough time lately. I just managed to build the primary cap and the cooling pipe (for GU5B) only:
I still dont know how to put the tube (GU5B): anode up or down. The device is made for the tube with the fillament connections up..
I thought to a bipolar VTTC too for the gmi90, center grounded, g2 modulated (as a drsstc). When the project will be started I dont know....
