  • Guests: 49
Bead (41)
Fumeaux (25)
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Railgun fired!
rp181
Sat Feb 21 2009, 08:11PM
First off, this is not in m project thread because i did not want to quadruple post....
Second, I accidentally did it without running the program for the rogowski coil !!grr
Now the info:
The railgun was fired today, with one digital camera and a digital camcorder (unable to connect to computer ATM). The injection pressure was probably around 50 PSI.
As most of you know, the enclosure is a 2 piece set, with a half inch bore. The projectile was a aluminum block with a V tail, 1.25" long. The target was a cardboard box packed with paper (for reference, the injection alone barely broke the first layer of cardboard) with a metal plate on the back. The projectile went through all the way, and put a .5" dent in the metal plate.
Here is the interesting bit:
I put a layer of kopr-shield corrosion inhibitor on the rails. When i opened it up, there was almost NO rail erosion. The only damage was a pit with aluminum in it at the very beginning, and a small deposit in the middle. Before i i washed it, there was still a film of the material left. Projectile corrosion was significant, so that will be main point of research from now on.
Im not very good at explanation's, so here are some picture's/video. If you have any questions, ask.
Video:
Notice two things:
1) the slow falling things. I think that is the plastic insulation on the rails.
2) The cable's. Those where zip-tied with 3 ties, and they still broke!
Pictures:
Th
Th
Th
Th
Th
I have tons of pics, so if you want something in particular, ask.
badastronaut
Sat Feb 21 2009, 08:27PM
badastronaut Registered Member #222 Joined: Mon Feb 20 2006, 05:49PM
Hmm very nice. Do you have a better pic of how the rails were bent 90 degrees?
Next time try shooting a hard target like a steel plate. Soft targets don't really say much.
What is the mass of the projectile? Use a copper clad projectile if you want to reduce projectile erosion. meow
rp181
Sat Feb 21 2009, 08:37PM
Two pics I found. They where just put in a clamp, and pushed.
Th
Th
I used a soft target because I had no thicker plate, and I wanted to recover the projectile.
hotcrazyfruit
Sun Feb 22 2009, 12:06AM
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
where did you get your rails? did you buy some buss bar? or is it flattened copper pipe? or what is it ?
rp181
Sun Feb 22 2009, 03:40AM
I bought the rails from mcmaster-carr, along with the busbars. The busbars are .125"x1" aluminum.
El_Roberto
Sun Feb 22 2009, 09:46AM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
Awesome, could you possibly post a pic of the target (after being shot) and a video?
rp181
Sun Feb 22 2009, 03:23PM
The cardboard box just has holes in it, I will get a pic of the metal plate. There is a video link in the first post.
badastronaut
Sun Feb 22 2009, 08:17PM
Fire it again!!! MEOW :)
rp181
Sun Feb 22 2009, 08:57PM
Whats with the MEOW?
I will fire it again, but the copper rail broke, so i have to remachine it. Rail has to be shortened by 3" too. The copper rail that broke is stuck in the G-11, I have to figure out how to get it out.
