  • Guests: 18
Kipmans (34)
DuartmaN (47)
04/24 Jack (13)
04/25 Desmogod (48)
04/25 Alex Smith (31)
sg3525 manual duty cycle adjust
kell
Tue Feb 03 2009, 08:32PM Print
kell Registered Member #142 Joined: Sat Feb 11 2006, 01:19PM
Someone might find this useful.
I worked out a good way to set the duty cycle on the SG3525 manually.
You certainly won't see this in the datasheet.
It tested well at 50 kHz and at several hundred kHz.
Vref
    33k
     |      pin1
     |      -in
 10k /       |
     \<--1k--+
     |      10k
    gnd      |
            comp
            pin9
Tie the noninverting input to Vref.
Interestingly, as you adjust the duty cycle up and down, the voltage across the 10k compensation resistor stays at a constant 1 volt.
With these component values, you can adjust down to about 15% duty cycle.
If you require the ability to adjust all the way down to 0% duty cycle, use 6k2 for the compensation resistor.
Tue Feb 03 2009, 10:01PM
Well you can do it with just a single potentiometer. Set the output of the error amp to low (inverting to vref, noninverting to gnd) and then use ~50k pot from pin 9 to vref to change your duty.
How is this possible? Because the error amp only uses single pull-up transistor on its output, and there is a 0.1mA current sink pulldown on pin 9, so by varying the resistance, you bring the voltage up and down smile
kell
Wed Feb 04 2009, 03:27PM
How did you suss out the fact that the error amp has a pullup resistor on its output? The error amp diagram in the datasheet shows what looks like a current mirror there.
Wed Feb 04 2009, 09:53PM
kell wrote ...
The transistor on the output of the error amp has a pull-down 100uA current sink/mirror. That's why you can connect a "pullup" pot to it to vary the voltage. I have done that and it works.
Thomas F
Fri Feb 06 2009, 07:55PM
Thomas F Registered Member #503 Joined: Sun Nov 19 2006, 06:37PM
Hi guys,
Sorry for piling on this thread,but I did not want to start a new one for a similar topic :).
I have this circuit from Dr.Kilovolt , I think.
Can this be used to generate lower frequencies ( about 25~50Hz ) and duty cycles down to about 1% ? Any modifications would be required ?
I would be running the entire setup from a 10V supply.
Cheers
Thomas
1233950104 503 FT63013 Flydriver1
Fri Feb 06 2009, 08:47PM
Probably yes, you would need to increase the tuning resistor value as well as timing capacitor. Duty cycle of 1% should be theoretically possible, but I think you will have a really hard time setting that value precisely. Maybe you could connect a second, much smaller pot in series with the big one for precise control. There's also the problem of pulse width drift with temperature, but I think it shouldn't be that bad.
Thomas F
Sat Feb 07 2009, 05:54AM
Thanks Dr.KV.
I was actually thinking of going for a multi turn poti,more expensive,but just one control to twiddle.
stress
Mon Mar 11 2013, 10:26PM
stress Registered Member #10265 Joined: Mon Feb 25 2013, 08:16PM
hello
i need a schematic with sg3525 with 310V DC at output and 18 Hhz, can anyone help me with some schematics?
Mon Mar 11 2013, 11:41PM
stress wrote ...
hello
Welcome.
Please fix or clarify your output frequency.
Unit multiplier symbols in SI don't include H.
Hempohertz?
Have you spent more than a minute trying the forum search tools here?
Ben Solon
Tue Mar 12 2013, 12:22AM
Addressing the original topic, that's what the discharge resistor in the timing portion of the circuit. 0ohms is zero dead time, more resistance adds more dead time, which for all intents and purposes is duty cycle. One pot.
