  • Guests: 17
Kipmans (34)
DuartmaN (47)
04/24 Jack (13)
04/25 Desmogod (48)
04/25 Alex Smith (31)
What is the best wire for a coil?
Plasmaarc452
Wed Jul 23 2008, 05:22PM
Plasmaarc452 Registered Member #1394 Joined: Sun Mar 16 2008, 06:18PM
I am just wondering what the best most economical wire out there is to make coils.
I was looking at
AWG 10-12 Magnet wire
or
Bare copper wire
So which one is better?
rp181
Wed Jul 23 2008, 06:34PM
how would bare copper wire work? ide say 8-10 AWG depending on power.
Plasmaarc452
Wed Jul 23 2008, 07:03PM
O sorry I had not thought of the "Bare part" I was thinking of copper wire with a thin coat around it.
Wed Jul 23 2008, 07:24PM
the wire with just an enamel coating is called 'magnet wire' or 'bell wire', and gives the best efficiency. You can usually find it pretty cheep on ebay, which is probably your best bet. Another option is to go down to the local home depot/lowes/osh/etc and pick up a spool of #12 wire (generally solid is recommended, but stranded should work just as well); the thicker insulation will reduce the magnetic field slightly, but for the larger diameter wires the effect is not as large as with smaller guns.
Plasmaarc452
Thu Jul 24 2008, 12:49AM
Thanks, I might go to homedepot and get the #12 wire since its easy to get but the magnet wire is better but I don't need insane efficiency.
Andyman
Thu Jul 24 2008, 06:59AM
I used romex wire for my coil and it works marvelously. Of course I had to split the whole length of romex down the middle and fish out the single conductor. It wasn't too hard though, and for something free, well....
Plasmaarc452
Thu Jul 24 2008, 07:11AM
What is romex wire? I think you are talking about that 2 part wire that you can split down the middle into two wires but I am unsure if thats what you meant.
Thu Jul 24 2008, 03:06PM
Romex wire is 2 or 3 insulated wires (generally solid #14 or #12 but you can get it up to #6) with an uninsulated #14 'ground' lead, inside of a plastic shell. They also sell it at home depot, etc. The white stuff is #14 main conductors, the yelllow is #12, orange is #10 etc etc
Dr. SSTC
Sat Jul 26 2008, 08:53AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
i use awg 15, but i dont dum that much power into my coil, it also depends ho you wind it
