Registered Member #95
Originally I just bought a bunch of el-cheapo foil caps from ebay on impulse with the intention of trying the LCLR topology again. It worked somewhat with a simple TL494 inverter, but I had to constantly adjust the frequency by hand to keep the capacitor voltage safe or current draw under control. All it would have taken was one slip and the bridge or tank capacitor would die. Meh. And I hadn't even gotten to tuning the matching inductor yet.
So I started designing a driver based on frequency adjustment to regulate the tank voltage, inverter current or inverter/tank phase. Which ever had the highest priority. (The discussion took place silently in this thread.) It would be nothing new actually, as this type of driver has been done before only with discretes. Tim's IH is complicated as hell though, and I wasn't going for something that elaborate. So after many different versions I eventually got something which worked and was reasonably simple. Behold.
As Richie has detailed on his site the LCLR arrangement presents a capacitive load below resonance and inductive above resonance, with inductive reactance being the most forgiving for a square wave inverter. Therefor an increase in supply current or tank voltage brings the VCO frequency up. On either side of resonance the impedance of the LCLR circuit increases, lowering current draw and resonant rise. With low supply voltages or proper loads neither the tank voltage nor the inverter current will need regulation, in which case the driver must lock onto the exact resonant frequency of the LCLR circuit for max efficiency and power. The PLL takes care of this by adjusting the VCO frequency to the point where the inverter output and tank voltage are 90 degrees out of phase (inverter leading the tank voltage), because this phase difference characterizes resonance in a LCLR circuit.
How does it work in the real world? Excellently. With light to no load the voltage or current protection kicks in and keeps the inverter from self destructing. With moderate to heavy loads the PLL kicks in and keeps everything in resonance. I've run it several times over the last few weeks and haven't noticed any odd behaviour yet. The only thing I dislike is that the voltage/current regulation isn't "smooth" but seems to oscillate somewhat. It's hard to explain but you can hear white noise whenever the regulation kicks in. Hasn't caused any noticeable problems though.
Anyway with the new driver finally done I can continue working on the LCLR topology. Atm I've narrowed the limiting factor down to the matching inductor which heats up fast. Before I can do any serious heating I need to make something more robust. Currently the inductor sports 16-filar 0.3mm litz wire, which I thought would be good for 20A at 100kHz. Hence the surprise when it started heating so badly. Is there nothing more to do than wind more litz wire or get copper strips? How does one make a power inductor?
Registered Member #1389
I don't know if this is practical, but you could cut some Al flashing into a proper width strip, and turn your matching inductor from that. As I understand it, Aluminum has a larger skin depth than copper, so it may be better in this situation, and the surface area will effectively give you a larger conducting area. Also, the windings may have enough surface area to dissipate generated heat better than the 16 filar litz wire you have.
Registered Member #1232
Sounds good Uzzors - I'm glad you got the controller working well.
The noise you noticed during current-limiting could be due to instability in the current control loop. Or it might be the sign of a potentially damaging low-frequency resonance between the bridge's DC blocking capacitor and the Lmatch inductor. (The DC blocking cap and Lmatch inductor will series resonate at a lowish frequency. Any control loop oscillation around this frequency is BAD!)
Re: Power inductor design, i'd use a large Mn/Zn ferrite E-core set, gapped and wound with litz. ETD and EC cores are designed to minimise the mean turn length and volume of ferrite, which is fine for a transformer, but it is not really what is wanted here. Power electronics books should cover the magnetics design.
I also doubled up the IRFP450s which reduced power dissipation considerably. With a single fan the inverter can run continuously I believe. Now if only the tank could do the same. The capacitors don't get warm themselves, which isn't bad considering how cheap they were. They do heat up from the immense heat conducted by the work coil though, an insulating crucible would help.
And some mandatory pics of redhot iron. The power of this IH isn't very impressive IMO, but at least it worked as a test bed for my new driver.
Water cooling of the work coil is essential otherwise it will eventually melt from the hundreds of amps passing through it. As you found it is also subject to the radiant heat of the workpiece too, if there is no thermal "lagging" to insulate the two.
Registered Member #89
Hi Uzzors,
Your work is awesome so far, get the water cooling running so you can ramp it up!
What I'm worried about is very poor heatsinking of your mosfets, and with sil pads, you really need far better if you want to push the little mosfet's limits. Your current heatsink doesn't look like good but for 20..30W of total dissipation.
As you are in any case going to use water cooling, could you make some sort of water blocks for each of those mosfet's - some copper pipe soldered to a copper block would probably be just fine for ~100W of dissipation per mosfet... When properly cooled I think a H bridge of IRFP450's might produce up to 3kVA. Only an estimation with my current experiences though, and not sure how much kW will that actually be in an LCLR IH.
Of course you must not use sil pads, mosfets need to be clamped to blocks directly and insulation provided by long plastic water pipes.
Cooling is one of most important things in power electronics, which many people completely underestimate and then wonder why do their semiconductors die.
Registered Member #941
is CPU/GPU waterblocks for pc enuf to cool a fet in a config like this ? If yes it would be a great deal since pc water cooling stuff is getting cheap nowdays, and i have some pc wc components, from hdd coolers to cpu/gpu water blocks to pumps and dedicated fluid and radiators.
Registered Member #1374
Hi, I just discovered the website of your project : great, exactly what I need ! I'll try to build someting very similar to yours.
For the matching inductor that heats, have you tried an air-core coil ? 45uH is easily feasible, I think. (I was also never really successful at induction heating, so maybe I'm wrong..)
