  • Guests: 42
Desmogod (48)
Alex Smith (31)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
Triggering SCR's
Tipp
Sat Mar 11 2006, 07:50PM Print
Tipp Registered Member #215 Joined: Sun Feb 19 2006, 09:14PM
Ok, well I've been doing research and looking into this kinda thing, but it's confusing the hell out of me. I found a few site that showed me this:
Scrwiring
What's the 9v battery for? It looks like he's running it in series with his bank voltage so it will appear +9v more. Resistor is obvisly for limiting current to the gate. Is that the proper way to trigger an SCR? [To have a higher gate voltage then anode?]
Link to site:
It's been a long week...maybe I'm just not thinking strieght...
Thanks once again for all your help...you guys are lifesavers...
[Edit: Fixed oversized picture]
Sat Mar 11 2006, 07:53PM
it is kind of hard to tell when we do not know what model the SCR is, but a 9v battery resistor and switch is a fine way to triger one.
Tipp
Sat Mar 11 2006, 08:00PM
Oh, sorry, duh! angry Let me grab you a datasheet here... [this isnt the one in the pic, just used it as an example]
There y'are cheesey Voltage code = 12 [1.2kV]
Sat Mar 11 2006, 08:43PM
A voltage between gate and cathode, and the current that it causes to flow, is what triggers the SCR. So there's a mistake in that schematic which shows the trigger voltage connected between gate and ANODE (or the cap bank connected backwards)
Tipp
Sun Mar 12 2006, 01:51AM
So basicly, instead of attaching the 9v negitive to the anode, it should be connected to the cathode? Seems easy enough...is there any other precaution I should be aware of doing it this way? I dont want my 9 volt battery to go 'pop' mistrust Already blew up a AA battery...but that was another project wink
Simon
Sun Mar 12 2006, 05:33AM
As long as you wire it up properly and the SCR is correctly rated, the battery should be fine.
You might want to take a peek at the Wiki page.
rupidust
Sun Mar 12 2006, 08:08AM
rupidust Banned
Registered Member #110 Joined: Fri Feb 10 2006, 12:23AM
Here is a nice quick sample to test an SCR.
Tipp
Sun Mar 12 2006, 07:32PM
Aight, well I tried sample circuit #1, and the LED turns on, but the thyristor won't latch. Is this normal for a huge power SCR like this? I have a 5P4M SCR in a TO-220 package which latches normally when tested in this manner.
[Edit: Currently reading the wiki page, whoever drew those pictures has some mad paint skills cheesey ]
rupidust
Sun Mar 12 2006, 10:47PM
rupidust Banned
Here is the resized schematic.
Mon Mar 13 2006, 01:09AM
the larger teh SCR the more power needed for it to latch. I think that you need about .5a for it to stay latched, and about .3a on the gate to trigger it.
