Registered Member #952
Hello there! I want to show you my minimalistic project I finished yesterday. It's a mini ion gun, made mainly from disposable camera components. It's zero budget because I already had all the stuff I needed for it! :) Some technical info: -Power source: one 1.2V AA 1200 mAh NiMH rechargeable battery (normal 1.5V non-rechargeable ones work also) -Inverter: the transformer from a disposable camera with its driver (220 ohm resistor and 2SD2504), puts out 330V -Voltage multiplier: 6-stage CW made from the small capacitor and diodes from disposable cameras, diodes are configured for positive output. Capacitors are 2nf (I suppose) -Limiting resistor is 10 Mohm -Discharge point is just a sharp needle -Grounding: user (the grounding wire in the handle is seen in the pics) The gun was assembled, of course, with hot glue (I love that stuff :) Schematic for the inverter was found here http://www.increa.com/reverse/dc/dcschem.gif, although my cameras were blue fujifilm ones, not kodak.
The performance was surprising when I tested it first time. I could feel the ion "wind" ~7 cm from the discharge point. It can also stick some small pieces of paper (4cm*4cm) to the wall for ~ten minutes. It gives some arcs of max. 5mm. Not bad for as simple device as this is, or what do you think?
Here's some pics of the gun:
And some video (wmv format because I hadn't got time to mess with mpeg2 encoders :( The arcs are 5mm or something
]1188034147_952_FT0_arcing.wmv[/file] All comments are welcome! :)
Registered Member #914
You may get better output if you make the end terminal negative. I made a similar device using a disposable camera power supply attached to an automatic spark unit for a gas stove.
Capper wrote ...
Scott
I've tried both, negative and positive output but the positive seems to be more powerful. I don't know why is this, but the positive just works better.
Registered Member #964
Wow! this is awesome. A bike ride down to target is a lot cheaper than $50 from Information Unlimited. It probably has more performance, but this little thing you threw together is COOL. I'm definatly going to build one of these some time :)
I'll give this project 11/10 for being budget-friendly and effective, not to mention looking plain cool.
Yep, it tickles somewhat, and it can give you an rf burn if you put your finger close enough ;) If you're gonna build this, remember the 10M resistor on the output. If you forget this, the CW will give you a very nasty shock :(
Registered Member #938
Nice! I have a small 15 kv supply but I want more power so I'm going to do what you did. I give it a 10/10 too cheap,fun and easy :) Also what type of diodes and there ratings ? I may get some along with my order and some capaciters then I will need one camera
Oh, about the positive output thingy, I find that If I use HV in +DC output I get all quesey. Maybe its just me, but I prefer -DC as it doesn't do this too me.
