  • Guests: 20
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
For Sale: High Power Laser Diodes
Tue Dec 05 2006, 04:07AM
As some of you know, I have an insane amount of 808nm laser diodes. About 25 20w bars and 20 50w bars.
Since I will not be able to use that many diodes in my lifetime, I have been selling most of them off (on ebay).
I just wanted to let you know that they are available, and see if any of you are interested. My asking prices are $60 for a 20w bar, $100 for a 50w bar. Add $100 if you want them mounted on a 1" mount (big block-o-copper that you just bolt down).
I also have some small (I think 20mw at 1550nm) DFB lasers (which means that they have a very small line width, like 1nm). I have no data other then that they work (I have mounted a few). Thinking about $5 a piece, add $50 for mounting on a small copper plate (like 10mm by 6mm by 3mm thick).
Finally, I have googles for 532nm, 808nm, 1064nm, 1550/1310nm, probably some other wavelengths (uv and ruby quoted) if anyone needs them. $60 new/$30 used.
Trading is cool too ;) ssy-1's are worth $90 of credit. Subtract $30 if you blew out the q-switch (if you put a lens that focuses it at about 1inch away and fire at 20j and you don't get a small floating spark then the q-switch is dead).
If you have a 1.6mm nd:yag rod (for diode pumping) I am all ears, or even better a mount for a 1.2mm rod. (I have a 1.6mm mount, but a 1.2mm rod, arrg)
Popp
Mon Dec 11 2006, 03:40AM
Popp Registered Member #251 Joined: Sat Feb 25 2006, 07:07AM
Awsome
, I want your laser stuff!
Mon Dec 11 2006, 10:16AM
My work buys quite a lot of 1550nm DFBs, but we need them packaged with a TEC and fibre output, and a nice data sheet. What are yours, bare chips?
Mon Dec 11 2006, 04:19PM
Mine are bare chips, but I could probably get some full modules. We scrap some insane amount of product becuase it doesn't quite meet the insane spec for the product the sales reps keep selling.
Just, you can't like sell them in a competing product cheesey
