Registered Member #60240
Hello friends of electronics
A dealer for used electronics supplied me two Tektronix 11000 oscilloscope frames, DSA 602 and DSA 602A. I was of the opinion that the devices were checked at least once before delivery. I switched on the devices in a large exhibition hall to test the frames and some 11000`s like 11A72 etc. That was not very smart. After approximately 5 to 10 minutes after switching on, one of the devices worked electrically initially faultlessly, biting smoke came out from both devices, which greatly influenced the air quality in the exhibition hall. Even one of these devices started to burn inside. After extinguishing the fire, the dealer agreed not to have checked the equipment before loading.
However, every experienced electronics engineer should know that one should deal very carefully with a very long time of unused HP and Tektronix devices. You should first connect these devices to a variable mains supply and the full mains voltage should applied step by step only after 2-5 minutes, in order to re-form various capacitors and to avoid potential explosions etc.
I would be interested in whether someone has already had similar experiences with smoke and fire when switching on old electronics.
The only positive thing followed this action was a corresponding price reduction.
You will get some pictures of the burned parts soon.
I hope I get from you also some hints how to repair these devices. The documentation of the Tek devices is unfortunately not sufficient in the 11000 series, in contrast to the 7000 series.
Registered Member #162
Variacs are excellent tools but I prefer putting a high wattage mains voltage filament lamp in series, (especially for smps, which does not apply here) I expect to see a brief flash from the lamp at power-on due to caps charging etc. then a dull or no glow for normal operation, and fully bright if things go wrong. The current limiting provided by the lamp usually protects from fire etc. A switch contact across the lamp allows full power operation once you feel comfortable.
When we see what was damaged other ideas may come.
Registered Member #230
usually it is the electrolytic capacitors depolarising---acting like short circuits this takes out the rectifiers and they go short circuit and now the ac on the DC rail kills at random. the other failure mechanism is a shorted turn in the mains transformer due to green spot
Registered Member #2906
Reforming old capacitors is perfectly possible, but i dont see how this can be done in a working device. Once you supply enough power for the operation of a device there is no way to limit the heat of the capacitor leakage current. So its a well meant thought having a light bulb in series, but it simply does not work like that.It only works if you put in a 50k resistor and dont turn the sucker on. But most poer supplies have some StBy power drainage so there is also no use.
