  • Guests: 27
Nicko (56)
04/20 gentoo_daemon (42)
04/21 kilovolt (49)
04/21 wannabegeekTC (49)
Franzoli electronics UD 3.0
wikus
Sat Jun 24 2017, 07:09PM
wikus Registered Member #58198 Joined: Sun Dec 27 2015, 11:15AM
Hi Guys
Has anybody looked at this new driver from Franzoli electronics. He only has a Facebook site. No details on the driver.
0
0 Pcb
Sat Jun 24 2017, 10:44PM
wikus wrote ...
Hi Guys
No.
Have you had a look at this driver:
it is the one you'd better use.....
Cheers, Finn Hammer
futurist
Sat Jun 24 2017, 11:04PM
futurist Registered Member #61400 Joined: Sun Jan 01 2017, 01:01PM
Steve Ward made PSoC based UD3 several years ago
hen918
Sat Jun 24 2017, 11:33PM
Yeah, never trust an engineer that draws GND sideways or upside down. :)
Exactly how does Franzoli claim to improve on Steve's design?
Alex Yuan
Sun Jun 25 2017, 07:39PM
Alex  Yuan Registered Member #9614 Joined: Mon Jan 14 2013, 10:00PM
It's the third revision of his drivers, not to be confused with the UD's. This version looks to have phase lead over his last universal driver. Though it's almost identical to a UD2.1/2.5 with a pulse width limiter.
1498419599 9614 FT180042 Img 0125
johnf
Mon Jun 26 2017, 09:30AM
Badly drawn circuits usually mean bad design
A circuit should flow and not grate on the nerves
I note 1n5819 s why not UF 1n4007 followed by a transil to clip the inevitable rogue pulse at some extended voltage that is going to turn the OCD amplifier into silicon oxide.
I started bottom left of the SCH and stopped there after seeing that, bound to be more gotchas in the rest
hen918
Mon Jun 26 2017, 11:10AM
johnf wrote ...
Yeah, he seems to be relying on the diodes to have sufficient internal impedance to damp the leading edge current spikes. Putting a resistor in series and capacitor in parallel to form a low pass filter would be far more effective than leaving them both in parallel.
Edit: and on further inspection, the lower MOSFETs on the deplorably drawn H-Bridge lack pull-down resistors.
Edit 2: (I should really stop looking at this circuit) When the feedback isn't connected / high impedance the 100k potential divider will pull the voltage on the NOT gate to ~2.5V which is on the borderline of being indeterminate.
teravolt
Mon Jun 26 2017, 01:51PM
and what difference is this over ud2.7 other than a pcb with through hole components. I wonder if they have permition to release it.
futurist
Mon Jun 26 2017, 02:05PM
Object like circuit board or schematics can't be copyrighted
