"FIREFLY" Dual 572b VTTC
SpaceWyzard
Registered Member #2318
Finally complete now that I've added the final piece (the toroid)! Currently getting 6 inch sparks. I have a level shifter installed but not activated (it was causing arcing from the secondary to the grid coil).
Secondary specs: 685 turns of 28awg 490khz fres 10 inches tall 2 inches diameter 4.25 inch toroid top load
Primary specs: 16 turns 14awg 5 inch clear acrylic form .001uF tank cap
Grid specs: 12 turns 28awg .002uF grid leak cap 1kohm grid leak resistor
Power specs: MOT with inactive level shifter Fan cooled
I hope you like it! This is my first completed coil!
SpaceWyzard
Sorry, pics didn't upload the first time!
