  • Guests: 42
Bead (41)
Fumeaux (25)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
Microwave mixer diode substitutes
Wed May 17 2017, 11:00PM Print
I've been experimenting making a simple UHF impedance bridge to test out some broadband antennas I've been working on for my SDR setup. (Thumbnet N3 and NooElec NESDR SMArt running SDRsharp for anyone who's interested.)
Does anyone know any cheap substitutes for microwave mixer diodes that would be good up to 2GHz - or even 1.5GHz if that's all I could hope for - please?
I have two Russian equivalents (or so it's claimed) of the legendary 1N23 microwave mixer diode, but I don't want to commit these until I absolutely have the circuit working with everything under control so won't be putting them at risk.
All help welcome. Thank you. Stella.
Thu May 18 2017, 06:22AM
I use BAT62-03W at 100's MHz, I believe that they work into the GHz range,
from the datasheet, BAT15 work to 12 GHz and are available as singles or duals or ring.
Link2 Link2
Thu May 18 2017, 07:47AM
The BAT15 looks promising and a big cost saving!
Thank you so much! :)
Thu May 18 2017, 08:49PM
Sulaiman, I bought five SMD dual BAT15 for £3.99 and they do look very useful as follows:
Qty. 5 New Infineon Schottky mixer/detector diodes. These are dual independent diode devices.
High sensitivity detector with low forward volts drop and low junction capacitance Due to the low barrier construction and low series inductance this device will operate as a mixer to 12Ghz
Very low forward volts drop 0.23V at 1mA
2 independent diodes on the 1 package, allows a detector with simultaneous positive and negative outputs to be constructed or use as a single detector with the other diode used for DC temperature compensation. Can also be used in a voltage doubler configuration.
Low junction capacitance 0.5pF typical
Operation to 12GHz
Allows greater flexibility for projects as the diodes are electrically independent of each other
SOT-143 4 lead package SMD Code S5s
A big difference pricewise to the 1N21 NOS microwave mixer diode at £6 each!
Thanx for the heads up! :)
Thu May 18 2017, 09:28PM
You may also be interested in pin diodes for switching or clamping, HSMP-382x series.
I have the 3822 type, quite useful for switching, but I've not worked at GHz.
also useful as a clamp on the antenna input etc.
I hate those stupid 4-lead SOT-143 SMDs ... prototyping is a pita
and note the BAT15 PIV rating ... 4 V !
Thu May 18 2017, 10:40PM
My basic concept for the UHF impedance bridge is adapted from a simple ham design that drives a panel
meter directly, but I can see that in order to keep the RF test signal voltage down to a safe level for the diodes, I'll have to amplify the output to drive the meter (a very nice Russian 100μA model with an arc of mirror). I've got a few OP07 and I'm sure that will be all I need for amplification at this stage.
I have very little experience of SMD construction, and what experience I do have tells me to avoid using those horrible little parts at any cost, but there's no way I could get my Z bridge to motor over 1GHz or so without using them.
I have another ham design for a Z bridge that the author claims is good to 3GHz, which it manages by miniature design. If I can make it work at 2.5GHz I'll be over the moon, as the claimed maximum frequency of my Nooelec NESDR SMArt SDR is 2.35GHz, and that of my Thumbnet N3 SDR 1.766GHz.
I'll put up some pictures when I've got something to show for it (parts heading my way from China at this moment!) in case anyone else is interested in designing UWB antennas for SDRs.
johnf
Fri May 19 2017, 06:59AM
1N5711
are some of the best they do do a surface mount version but I use the legged version 2 pf junction capacitance is about as low as you can go and VF starts at 0.25 volts so equiv to germanium
Fri May 19 2017, 09:53AM
I've used quite a few 5711s, they are excellent at VHF (2m)
(e.g. compared to 1N4448/1N4148)
I doubt that they will be much use at 2.3 GHz, but have not tried,
at 2.3 GHz the wavelength is about 100mm on a pcb,
so the overall length of a 5711, even with short leads, becomes a significant part of a wavelength,
if you are smart you can compensate for this ... I can't.
EDIT: I stand corrected,
I just googled "5711 GHz" and found lots of 2.4 GHz detectors etc.
but based on capacitance, (at 2.4 GHz, 1pF = -j69R)
1N4148 4 pF
1N5711 2 pF
BAT62 0.35 pF, 0.6pF max
BAT15 0.35pF max
Hazmatt_(The Underdog)
Fri May 19 2017, 04:05PM
Check Minicirciuits. They have mixers, couplers, detectors, everything except isolators (not sure why that is), and they are reasonably priced.
Shipping may be unreasonable though because they're here in the states.
Fri May 19 2017, 04:37PM
Thanks guys - quite a bit of experimenting to be done with all these suggestions! :)
