Registered Member #61373
I am planning to add 2 Mots to my dual Mot stack, Hv connected in parallel. The 2 new ones are from 2 different microwaves, and are slightly different in size. The 2 new Mots are almost as large as the Mots I have now.
With resonant caps, do the caps have to have identical specs too (uF)? What will happen if one cap is .85uF and the other is .75uF?
Registered Member #72
Sounds like you're gathering together all the elements for a mourning family.
Post a schematic of what you have now, specs for what you think it does now, what you want it to do, and a schematic of how you're intending to modify it.
Registered Member #162
Whenever you put similar but not identical transformers in parallel there are two main situations to consider; . on load, each primary voltage will be greater than the load voltage so will contribute a current of (Vsec - Vload)/(secondary impedance) each. so the lower voltage and/or higher impedance transformers of the group will supply less current each to the load than the higher voltage and/or lower impedance transformers . off load, due to slightly dissimilar secondary voltages, one or more secondaries will be above the common voltage, and one or more below it so one or more transformers will be 'sourcing' current and one or more will be 'sinking' current. MOTs have effectively high output impedances so the circulating currents will be smaller than full load currents, so no problem. Normal transformers with no deliberate flux leakage paths (or MOTs with the shunts knocked out) have a low output impedance, so the circulating currents in mis-matched transformers could easily exceed rated currents.
I consider ONE MOT to be potentially LETHAL four in parallel just makes your corpse smoke quicker
P.S. How are you going to power the four MOTs in parallel ? can your a.c. supply provide the required power ?
Dr. Slack wrote ...
What I have now, 2.8kVAC 2.7A:
How I'm going to modify it, 2.8kVAC 5.4A:
I'm using induction values as an example. I don't know the exact inductance. My mots are identical now, but the 2 newbies are slightly different in size, and a different brand. They should both be in the range of 2,100 - 2,200v
Sulaiman wrote ...
I have 2 outlets, both adjacent and connected to separate fuses. One outlet can supply 2 MOTs (resonant config. only) without blowing the 30A fuse.
Registered Member #102
What you have appears to be something that will generally work. However, I cannot fathom what you could possibly want to do with all that current. I agree with Sulaiman here: you are creating something far past what is considered to be lethal.
Registered Member #2906
Stop whining about safety, 4 mots arent more dangerous than 1 alone if mishandled. More important is, that his simulation lacks the coupling factor statement. It feels like this config will have strange load dependent behavior. Try to actually simulate it (like to share the .asc?)
ScottH, what you are trying here can spell out to be disastrous.
This is generally correct, but by adding caps in series, the leakage inductance might be cancelled, which can lead to large currents between the transformers and consequently very high voltages due to resonance conditions. For an unlucky choice of caps and transformers, the whole thing can blow up spectacularly.
Uspring wrote:
Omit the caps and you are much safer. Relatively.
So if Scott wanted to avoid the possibility of cancelling out the shunt-enhanced leakage inductance that would otherwise protect his parallel MOTs, he should parallel the MOTs directly. Then if he wanted to play with the resonant caps, add a parallel connection of them between the load and the commoned MOT HV terminal? Just a thought. Not as good a thought as putting the MOTs back in the box and having a cup of tea instead, but a thought.
