  • Guests: 38
Nicko (56)
04/20 gentoo_daemon (42)
04/21 kilovolt (49)
04/21 wannabegeekTC (49)
What is the frequency output (Hz) for this NSTs secondary?
ScottH
Mon Apr 24 2017, 04:47PM
ScottH Registered Member #61373 Joined: Sat Dec 17 2016, 01:45PM
I looked for the specs online, but no luck. The smaller newer NSTs like this use smaller parts, and put out HF current. This model should use a switch mode power supply, 3kv @30ma. Link2
GrantX
Tue Apr 25 2017, 08:27AM
I'm not sure about that specific unit, but I have a furnace ignition transformer and electronic NST that both operate around 25kHz
Kolas
Thu May 11 2017, 10:01PM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
It should be possible (likely with great difficulty) to measure the output frequency. this would probably involve the use of a very large array of resistors and an oscilloscope.
Suffice to say, if you cannot hear the arc, its 20+ khz.
