Vacuum tube tesla coil build help.
Bud
Registered Member #54930
Hi all, The picture below is of the primary tube completely covering the secondary. I have a YU-108 tube that needs a 700 volt @ 1 amp max. bias control to oscillate the tube. I cannot get enough drive power with a tickler coil to do start oscillation. I need to know if there is a IGBT or Mosfet that can work at 350- 360 kHz. and 700v at 1 amp. I am considering driving this with a signal generator or one of Steve's driver boards. Or is there another route I can take?
I have tried modifying my other VTTC with a large coil around the secondary and there is enough power but the tuning is way complex.
Any help would be appreciated.
woodchuck
Registered Member #39190
There are surely other choices these days. But even 15 years ago, the BUZ80A would have met those requirements.
