SOLD - Monster 120v -> 21kv potential transformer for sale.
redruM69
Registered Member #31557
HUGE 175:1 instrument transformer. Weighs 144lbs. Model ABB VOZ-15. Manufactured in 2014 I ballasted it down to 1500w and pulled some nice arcs. These reference transformers are built like a tank, and can often handle MUCH higher power than rated for a limited amount of time. In fact the ANSI BIL is rated at 150kv on this transformer!
Make me an offer. Feel free to call or text (801)413-3417.
Located in SLC Utah. Freight available if needed.
Registered Member #2099
Description says 175:1 instrument transformer. Shouldn't the title say 21000 to 120 volts? Are you hinting that the taker might misuse the item?
On your nameplate picture there's a figure like 11 near the top right. Would closer inspection show: [kVA 1.1] ?
Too bad I have no road trips planned to the SLC vicinity.
redruM69
It's continuous duty rating is 2000 VA @ 30 degrees C. Easily double or triple that for intermittent duty. 1.1 RVF/FTC. Rated Voltage Factor.
redruM69
SOLD!
