  • Guests: 24
GrantX (34)
03/30 Adam Horden (39)
03/30 Mr.Warwickshire (23)
03/31 Swedish Coiler (41)
Another slayer.
Wolfsangel1
Mon Jan 09 2017, 07:35PM
Wolfsangel1 Registered Member #61395 Joined: Wed Dec 28 2016, 03:44PM
Greetings everyone! It is my first post and I am from Latvia. It is my fifth tesla coil. I made it from some parts from previous coils and another “garbage”.
Specs:
Secondary: 30 x 7,5 cm ( ~11 x 3 inch), with 0,27 mm wire;
Ballast: MOT primary;
IRFP 460, protected from source to drain by 13 1,5KE33CA in series;
Interrupter – Power supply controlled by triac and MOC3063M, duty cycle – 10 - 100 %.
Streamers about 25 – 30 cm. It’s possible to make them bigger, but transils and mosfet will become very hot.
1483990447 61395 FT0 Dsc 3521
Some sparks:
1
2
Patric
Mon Jan 09 2017, 10:51PM
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
I love Slayers, good work!
Tue Jan 10 2017, 07:26AM
Great results, I guess it is never too late to build something simple, I should give the slayer a go soon :)
flannelhead
Mon Jan 16 2017, 11:51AM
Great work. The mechanical construction is also beautiful. What kind of a power supply are you using?
Wolfsangel1
Wed Jan 18 2017, 08:31AM
Thanks.
Power supply is half-wave rectifier (mur1560), connected to 220 V AC.
Fri Feb 17 2017, 07:37PM
Same here.
Made a test coil from a cardboard former, didn't expect it to work but it seems stable and locks on to the MSF signal somehow.
Was an excellent demonstration of how not to build an MSF receiver because it also picked up LED lighting and someone's NFC that they had turned on by mistake.
Tuned using Peak Atlas LCR, although the coil did drift a fraction of a percent when dried out after Superglue encapsulating this is swamped by the heat induced resistance changes from all that copper (1600+ turns salvaged clock wire)
EDIT: Latvia? are there any other HV enthusiasts/coilers there?
I once spoke to a guy from the Ukraine about one of my projects, apparently they might know Kreosan!
