  • Guests: 12
Kipmans (34)
DuartmaN (47)
04/24 Jack (13)
04/25 Desmogod (48)
04/25 Alex Smith (31)
A Small Surface Plate for Measurement.
Mon Dec 12 2016, 07:19AM
Heres a little side project i thought id post.
1481527140 2431 FT0 Milled 1
I milled a piece of T6 aluminum to hold an articulated arm. Im fortunate my current employer lets me mill personal pieces and powder coat them.
1481527140 2431 FT0 Surface 1
When the surface plate arrived it was in a huge cardboard box, loaded with heavy bubble wrap and shredded cardboard. Then there was a wooden crate inside with still more shredded cardboard. I was pretty worried about breaking into the box and breaking it.
1481527140 2431 FT0 Surface 2
I had the Aluminum powder coated "candy red". Here you can see i bought the 2-ledge type for carrying.
1481527649 2431 FT1630 Drill Press
I was real careful drilling that 1/2" hole.
1481527649 2431 FT1630 Cement
The red arm was bought on Ebay for 16 USD the two pieces are matched pretty well in color.
1481527915 2431 FT1630 Stud 2
Boring 3/8" holes using a diamond bit was really sketchy, i was afraid they'd wander around, but it when i measured they were right where i wanted them.
1481527649 2431 FT1630 Stud
Here you can see the holes, the scuffed surface and the 1/4-20 studs. it was all epoxied together.
1481527915 2431 FT1630 Surface 4
It seems to work perfectly.
Kizmo
Mon Dec 12 2016, 11:17AM
Nice work! Better have that Haas Z-axis waycover fixed before it fails catastrophically.. been there cheesey
Mon Dec 12 2016, 07:00PM
Im not the one who milled into that vice either.
Sun Jan 29 2017, 09:53PM
I 3d printed a little stand to turn this dial indicator into a gauge plunger for my 3d printer table setting.
1485726787 2431 FT178492 Dial
