  • Guests: 26
GrantX (34)
03/29 GrantX (34)
03/30 Adam Horden (39)
03/30 Mr.Warwickshire (23)
wave optics kit
Physikfan
Sat Oct 29 2016, 06:41PM
Physikfan Registered Member #60240 Joined: Mon May 16 2016, 07:01PM
This is a wave optics kit with high quality items:
P1190280400x356
P1190281400x224
Physikfan
Sat Oct 29 2016, 06:50PM
Items of this wave optics kit
Spectral tubes helium, neon, argon and hydrogen
Reflection grating 650 lines / mm
adjustable slit
Direct vision prism
Fluorescent screen
Hollow prism 60 °
Flint glass prism 60 °
Filter red, in slide frame 50 x 50 mm
Filter green, in slide frame 50 x 50 mm
Filter blue, in slide frames 50 x 50 mm
Filter split red / blue, 50 x 50 mm
Grid 5, in slide frames 50 x 50 mm
Grid 10, in slide frames 50 x 50 mm
Grid 20, in slide frames 50 x 50 mm
Measuring slide 30, millimeter graduation
Double wedge gap, in slide frames 50 x 50 mm
Single slit 0.2; 0.3; 0.4 mm, in slide frames 50 x 50 mm
Double slit 0.2; 0.3; 0.4 mm, in slide frames 50 x 50 mm
Multiple slits 0.2; 0.3; 0,4 mm, in slide frames 50 x 50 mm
Obstacles 0.2; 0.3; 0.4 mm, in slide frames 50 x 50 mm
Physikfan
Sat Oct 29 2016, 07:04PM
List of experiments with the wave optics kit:
2.1. Experiments on the propagation of light and photometry
2.2. Experiments for the spectral decomposition of the incandescent light and for the generation of a continuous spectrum
2.3. Experiments for generating discontinuous spectra
2.4. Experiments to demonstrate the invisible areas of the spectrum
2.5. Experiments to unite spectral colors
2.6. Experiments on interference by reflection and refraction
2.7. Experiments on interference by diffraction and scattering
2.8. Experiments on interference by diffraction at the double slit
2.9. Experiments on interference by diffraction on the reflection grating
Physikfan
Sat Oct 29 2016, 07:10PM
Direct vision prism
P1190270400x216
In front of a fluorescent tube (Hg-lines)
P1190308400x428
Physikfan
Sat Oct 29 2016, 07:12PM
Reflection grating
(Hg-lines of a fluorescent tube)
P1190295400x282
Physikfan
Sat Oct 29 2016, 08:00PM
Literature:
"http://www.gvp.cz/~vinkle/mafynet/ fyz_5_6lete/vlnova_optika/WaveOptics.pdf"
