  • Guests: 25
Desmogod (48)
Alex Smith (31)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
"LightningStorm" vacuum tube Tesla coil project
Avenger
Thu Aug 04 2016, 02:43AM Print
Avenger Registered Member #1275 Joined: Wed Jan 30 2008, 09:33AM
My last VTTC project. This project started one year ago, but only a month ago, the first sparks were obtained.
The objective of the project - to build a powerful vacuum tube Tesla coil on the basis of soviet metal-glass high-power air-cooled tetrode GU-39B-1. This tube is capable to dissipate at the plate power around 6kW. And its output power is 13kW.
It was made the plate and filament transformers. The filament transformer provides 6,6V and 100A. Plate transformer is wound on the base of the output transformer of the high power tube audio amplifier UPV-1,25 (russian УПВ-1,25) used two GU-81M tube in push-pull output stage. Its core is made up of steel plates of thickness 0.35 mm (core sectional area of 49cm^2). It provides voltage 5kV and 2A peak сurrent (nominally 1,5А)
In the power supply used level shifter with eight 1uF 16KV capacitors and homemade diode pack at 50kV and 3a. All ceramic capacitors in circuit - soviet K15U-1 ("doorknob") or K15U-2 type.
The tube installed in a steel cylinder with polyamide insulator at the bottom. Centrifugal fan "bahcivan aorb" (BRDS 180-60, 1200 m³/h) is used to cool the tube. Tube operates in triode.
The secondary winding contains 800 turns of 1mm copper wire on 160x800mm PVC pipe. Epoxy coating. 20x5cm aluminium toroid is installed.
The primary is a 35 turns of 4mm copper wire on 250x500mm PVC pipe. Taps on each turn, starting with the 28th turn. Winding height is 28cm. MMC capacity is 2nF (4x470pf).
Feedback winding has 14 turns of 1.5mm copper wire (taps of the first 5 turns). Located above the primary winding. Grid leak circuit is 200 Ohm and 14nF.
Tesla Coil working in staccato mode. In the cathode circuit installed triac, which is controlled by circuit in 555 timers (based of the staccato cotroller of Steve Ward).
At this moment VTTC gives streamers up to 1.5m length. The length of the streamers is limited to the power of the plate transformer and power mains capability (mains 230V 50Hz, current consumption up to 40A).
1470276086 1275 FT0 Img 0848 1470276086 1275 FT0 Img 0850 1470276086 1275 FT0 Img 1131
1470276213 1275 FT0 Img 0906 1470276213 1275 FT0 Img 0943 1470276213 1275 FT0 Img 1024
1470276213 1275 FT0 Img 0340 1470276213 1275 FT0 Img 0342 1470276213 1275 FT0 Img 0137
1470276991 1275 FT0 Img 0747 1470276991 1275 FT0 Img 0858
1470276991 1275 FT0 Img 3160 1470276991 1275 FT0 Img 3158
1470276991 1275 FT0 Img 3189 1470278417 1275 FT0 Img 0138 1470278417 1275 FT0 Img 0040
1470278417 1275 FT0 Img 0122 1470278417 1275 FT0 Img 0124
1470278417 1275 FT0 Img 0134 1470278417 1275 FT0 Img 0135
Video here: (work with triac)
And here: (work with thyratron TR1-5/2)
Thu Aug 04 2016, 06:32AM
Wow. You did a great and throurough job on this coil.
Windigns transformers, many bits and pieces home made, I really like it.
The sparks are beautiful, bit of a shame that the loud air cooling ruins the lovely sound of the sparks. CW mode is insane :)
I am wondering if you should try a larger topload to avoid so much near horizontal branching, was in the picture where sparks hit the tube heat connections :)
Would you mind sharing how you incorporated the thyratron tube as modulator?
Hydron
Thu Aug 04 2016, 12:20PM
Hydron Registered Member #30656 Joined: Tue Jul 30 2013, 02:40AM
Very impressive!
Thanks for sharing the photos/videos of the coil.
Avenger
Thu Aug 04 2016, 03:32PM
Thank you! But still a lot of work before the final realization of the project. Here is a photo of thyratron interrupter. It consists of a thyratron, the filament transformer (thyratron requires 5V and 15A), the bias power supply and IRFP450 MOSFET. The value of the negative bias on the grid of thyratron is about 24-30v. Interrupter works from my synchronous staccato controller unit (shown in photo).
1470323916 1275 FT177486 Img 0148
1470323916 1275 FT177486 Img 0149
1470323916 1275 FT177486 Img 0069
1470323916 1275 FT177486 Img 0066
Soviet mercury thyratrons TR1-5/2
1470324574 1275 FT177486 Img 1341
And the video, where interrupter operates as a dimmer (use mains 230V and 300W bulb load):
Avenger
Thu Aug 04 2016, 03:36PM
The circuit of the thyratron interrupter shown in the photo. Negative bias power supply and VTTC generator unit is not shown.
1470324974 1275 FT177486
Thu Aug 04 2016, 07:09PM
That glowing vacuum tube looks so cool.
Fri Aug 05 2016, 06:40AM
Thank you for all the extra information.
I have for many years, since I built my first VTTC in 2009, had a large QB5/2000 tube (2kW plate dissipation) and recently bought a TGI-700/25 thyratron tube(that however is mismatched with operating the QB5/2000), so your thread here sparked a little on getting on with the planning of that project :)
Dr. H.
Fri Aug 05 2016, 11:57AM
From a big tube lover - GREAT project smile
Just a question (not being smart or anything -really asking) - what is the advantage of using a thyratron over the simpler triac-staccato circuit ?
Well we can't argue wit the coolness factor.
Avenger
Fri Aug 05 2016, 09:18PM
Dr. H. wrote ...
The advantage of using a thyratron is not found. So now I use TRIAC interrupter.
Sat Aug 06 2016, 04:40PM
Avenger wrote ...
Dr. H. wrote ...
Differences between cathode modulation and anode modulation, Link2
