Bodged to the max
Registered Member #96
This is an Ipad Mini, worth saving (just) but has a bad battery apparently as it keeps beeping and won't charge. I've hooked it up to an external charger and so far so good, did a full cycle to 0 (3.2V) and recharge with low current 150mAh single chip charger and so far it seems to be working. It wasn't even powering a RaspPi before, now it runs for about an hour with two external CDROMs hooked up and then I left it charging again.
any ideas? -Andre
also see (not mine)
