  • Guests: 55
Bead (41)
Fumeaux (25)
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Dual 813A VTTC — based on Steve Ward's design: HELP NEEDED
angadsri
Sat Jan 23 2016, 12:23PM
angadsri Registered Member #55297 Joined: Mon Jun 22 2015, 04:36PM
Hello!
I'm a high-schooler from India currently working on finishing up a tesla coil model, based on Steve Ward's dual 811A schematic.
I was hoping I could get some advice/help with it, is there anyone who could lend me a hand, please? I'm somewhat new at this, and I'd really appreciate any and all support from the wonderful members of this forum.
Please find here a document with a report on the Coil, I'd love advice.
Thank you!
GrantX
Sun Jan 24 2016, 06:07AM
Welcome to the forum!
I'm not quite sure what area you need help in. Do you want advice for the physical construction and tuning of the VTTC, or help with the theory of operation and math for the report?
If you need help with the construction, it will be very useful to post pictures of your current progress. With pictures we can see if anything needs to be improved or changed, it will speed up the help you receive.
In your report (haven't read it all yet) I noticed you were looking for a program to draw circuits. I'm currently using "TinyCAD" which is a small free program that's super simple to use. It doesn't have a vast library of symbols, but its enough for non-serious hobby projects.
angadsri
Sun Jan 24 2016, 10:31AM
@GrantX, thank you!
Well, I sort of need help with both those areas. :P
Thanks for the circuit advice, made my diagram which I hope is accurate — please find it attached.
Build photos also attached, please do tell me if you want me to put a specific angle.
My current objective is to tune and test the coil — I need it to work at least once ASAP (preferably within the week), but I'm fairly under-confident of my own calculations and efforts. :/
I have connected the vacuum tubes properly (I hope), based on the manufacturer's guide on its terminals, and got the rest of the circuit ready. Even though I have studied theory, I'm still unclear about the purpose of the computer power supply, and also about whether using this on 240V supply (which we get in India) versus the 110V Mr. Ward used merits any changes to the schematic.
At the moment, the flaws in it are, as I see it:
1. How to connect the computer power supply
2. How to make the inductors parallel to the two 30Ω resistors — simply loop the same copper wire used on the secondary around the resistor? Do I insulate that?
3. Tuning
I apologise for my novice-ness, I might have bitten off a tad more than I can chew with this, but I'm still determined to see this through to the end.
Please find the photos at the link, I apologise for not putting them here, somehow it isn't allowing me to upload: Photos link
Tue Jan 26 2016, 06:49PM
Your schematic is incorrect, that is, you have drawn the vacuum tubes with the wrong internal components. I cannot find a datasheet for "813A", but i can find them for "813", and it shows the tube has multiple grids which requires some extra components.
From reading the datasheet, we find that G1 (grid 1) is the main control grid, takes the same function as the grid in a triode. G3 is an "internal shield" which, for Class C oscillator is to be connected to 0V (ground). G2 has to have a voltage which tracks along with the plate voltage supply, this is simply accomplished with a resistor from the MOT output to G2. It is unclear whether there needs to be a capacitor to filter this voltage at G2, but if so, i think a value of 1nF with a rating of 3kV (small ceramic disc cap) would be OK. I would try without this capacitor at first. The resistance to feed G2 is not something i know, but the datasheet suggests no less than 5k ohms, and I've seen other VTTC schematics with higher resistance here for smaller tubes. I would think 10K ohms will work, but maybe some tuning can be done here to improve performance. Less resistance should allow more tube current, but too low of resistance could damage the grid and ruin the tube, so keep it to 5k or greater. I have attached a schematic showing 1 tube, you can figure out how to make it for 2 tubes.
I see you have the 30 ohm resistors already in circuit. Simply use 2 new pieces of wire (say 40 cm long each) and wind each piece around each resistor and solder the ends to the resistor terminals. The process and result should be very simple, you only need about 10-15 wraps of wire on each resistor. This coil will look like a "short circuit" across the resistor except at *very* high frequencies (10's of MHz) where this small coil will have some reactance. I have attached a picture demonstrating the construction. Wire insulation does not need to be thick (magnet wire would be OK), but the wire should be heavy gauge. I show a thin wire because this was just to demonstrate, but you should use something >1mm diameter.
Practically speaking, you could simply eliminate the 30 ohms resistors and inductors (just short circuit them) as they are mostly there to help protect the vacuum tubes if there was an internal arc-over between the plate and the grid.
Also, i noticed you are trying to solder connections to the tube, i would not do this! Applying heat to one small area (the contact) of the tube can thermally stress the glass to metal seal and ruin the tube. Hopefully your tubes are still OK. Tubes are meant to be connected with some sort of spring/clamp connection which clamps onto the pins without soldering. Also, a proper tube socket does not rigidly fix the positions of the tube pins, but rather, allows the tube pins to move slightly as the tube heats up and physically expands the distance between pins.
1453834171 146 FT175027 813 Scheme
1453834171 146 FT175027 Plate Protector Demo
EDIT:
With a bit of searching, I found John Freau's suggestion for dealing with the 813 "extra grids", sounds easy and effective. I believe he is saying connect G2 directly to G1, and connect G1 to the rest of the circuit as usual. G3 still connects to cathode ground.
" Still trying to get this dual 813 VTTC going, with no luck. The
main problem right now is figuring out what to do with the extra
grids (G2 and G3) of the 813 tubes."
The easiest approach is to tie the control grid and the screen
grid together and use the combo as the control grid. The suppressor grid
should be grounded to the cathode.
If you want to run the screen grid separately, use a 40k ohm resistor
of about 100 watts. It will draw some current in it's role as a dropping
resistor. You want about 700 volts on the screen. These resistor
values are for a single tube.
In my setup I used a level shifter (ac doubler) MOT and obtained
16" sparks without staccato from a single 813. Longer sparks
are probably obtainable with some better adjustments. I show some
similar schematics and stuff at my website at:
http:hometown.aol.com/futuret/page3.html
John
angadsri
Sun Jan 31 2016, 01:05PM
Thank you so much, Mr. Ward! I'll do those things.
The reason I had to put this 813 was that the website I designed the schematic on didn't have the accurate diagram, so I'll make one myself based on your super-helpful photo.
EDIT: the specs for the particular tubes I have seem to make them look identical to the 811As you used in your original VTTC, so I connected it accordingly, even though the schematic doesn't show it.
Signification
Sun Jan 31 2016, 06:08PM
Considering that the wire-wound ceramic resistor is also a similar coil, should some thought be given to winding these "TWO" coils in the same direction??? The internal resistor winding direction should be simple to determine.
