Using IRFP460LC instead of IRFP460 in halfbrigde SSTC running of rectified mains
Phil33ts
Registered Member #57473
Hey I've bought some cheap IRFP460LC. My question is are they a direct replacement to IRFP460? Datasheet says:
wrote ...
• Ultra Low Gate Charge • Reduced Gate Drive Requirement • Enhanced 30 V VGS Rating • Reduced Ciss, Coss, Crss
I want to use them in my halfbridge SSTC that runs on rectified mains 230V AC. Will I have to change gate drive resistor (10 ohm atm) for this new transistor? Thanks in advance!
Sigurthr
Registered Member #4463
It should work fine. You shouldn't have to change the gate resistance, as reduced Ciss. The RdsON is still higher than what I recommend, at nearly a third of an ohm, but people use the 460s successfully, it's just not my cup of tea dealing with that much heat.
