  • Guests: 42
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Bigcoil
Adam Munich
Tue Dec 29 2015, 06:08PM Print
Hi all,
Several years ago now I built a giant musical tesla coil, but never told any of y'all about it.
Figured it's worth sharing smile
- Bridge caps store 1.2kJ with 120mOhm ESR
- Tank is an MMC from the foil plate CDE caps everyone loves
- Coil diameter, 14 inch. Built on custom formed fiberglass tube.
- H bridge is 2x CM1400DU-24NF, with isolated 20A gate drivers. ~300ns rise time, beats the datasheet by a factor of 4 smile
- Peak current limited to 1500A
- Bus voltage 350V or optionally 590V on 208V.
- Polyphonic midi control
It took about a month to built. Been going strong ever since, even surviving multiple rainstorms.
Signification
Tue Dec 29 2015, 06:33PM
Is that "popcorn"?
woodchuck
Tue Dec 29 2015, 08:00PM
woodchuck Registered Member #39190 Joined: Sat Oct 26 2013, 09:15AM
I still have a 45 of the Hot Butter original.
Impressive coil! Impressive setting!
Adam Munich
Tue Dec 29 2015, 08:06PM
It is popcorn. makes a great show on the coil. smile
]popcorn.zip[/file]
Signification
Tue Dec 29 2015, 08:45PM
@woodchuck:
That's it! The old 45 by "Hot Butter"
@Adam:
...ever considered "Flight of the Bumblebee?
GREAT COIL!
Build a twin and put on "Dueling Banjos"
We know the light can be modulated, but what about different colors per coil setup?
Sigurthr
Wed Dec 30 2015, 04:06AM
Very nice! I remember seeing a few build photos on facebook at the time you were working on it, it's great to finally see the final result.
Wed Dec 30 2015, 07:24PM
It is pretty clear that you are running without a single break out point, but do you have multiply small break out points or is it just the toroid having a real uneven surface?
Justin
Sat Apr 09 2016, 02:29AM
Justin Registered Member #46164 Joined: Wed May 07 2014, 08:16AM
Might be interesting to put different metal salts on the various breakout points.
Art
Sat Apr 09 2016, 01:17PM
Art Registered Member #57369 Joined: Fri Sept 18 2015, 01:24PM
What’s happening when a spark lights the whole camera frame?
Happens 3 or 4 times.
Justin
Sun Apr 10 2016, 07:46AM
Art wrote ...
Probably a ground strike.
