  • Guests: 27
Nicko (56)
04/20 gentoo_daemon (42)
04/21 kilovolt (49)
04/21 wannabegeekTC (49)
tinyQCW
loneoceans
Tue Nov 24 2015, 08:18PM
Hello all,
I've been working on and off on various projects recently. One of them turned out pretty nice so I thought I'd post something about it. smile
The motivation of the project was to make a very small QCW coil that could easily fit on top of a table, but still have good performance and be 'plug and play' easy to operate. The size restriction was that it needed to fit into a medium size USPS box (!). The result is a very compact coil, yet capable of sparks just over 32" or so despite its small size! (more than 13x) Power input is from a single IEC input cable from the wall. Because of it's small size I've called it tinyQCW (QCW 2).
22644185188 0e57488f0b C
The coil uses a full bridge of TO247 IGBTs and has a relatively small 3.5" diameter x 2.4" long winding (so it's a pretty fat ratio), with a small sheet metal toroid. Overall the coil runs pretty cool with the only part getting warm being the secondary coil. Coil has been run up to about 1.25kVA input (no PFC) for a few minutes whereby the secondary gets up to 60+C! I could probably optimize to make it smaller but I'm pretty happy with how it has turned out so far.
Here's a fun video of the coil in action, varying the pulse frequency and power.
Many thanks to all the kind and knowledgeable people who have helped out so much including Steve and Chris - this project would not be possible without their prior work and advice. More to come soon, thanks for reading!
nzoomed
Tue Nov 24 2015, 08:31PM
nzoomed Registered Member #54503 Joined: Sun Feb 22 2015, 10:35PM
Thats pretty cool!
Hopefully with newer IGBT technology, one day we will be able to build giant ones the same size as alot of large DRSSTC's out there!
loneoceans
Tue Nov 24 2015, 08:38PM
nzoomed wrote ...
Thats pretty cool!
Actually it's already possible smile As for myself I'm currently working on a bigger coil but it's difficult because I'm running out of space in my apartment..
Phillip Slawinski
Tue Nov 24 2015, 11:06PM
Phillip Slawinski Registered Member #1732 Joined: Thu Oct 02 2008, 02:34PM
Very cool. I need to make something like that. I enjoyed seeing it at my teslathon.
