  • Guests: 23
Desmogod (48)
Alex Smith (31)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
Using PLLs for resonant tank control
Wolfram
Thu Oct 08 2015, 03:11PM Print
As I've been working with my induction heater project, I've played a lot with PLLs, and they have given me lots of trouble. This generally seems to match the experience of other members here as well. A few days ago, I started digging deeper into the problem and I discovered something very important. The usual XOR-type and edge triggered detectors are both inherently unsuitable for the control of resonant tank circuits, for different reasons. No wonder people have had trouble with them.
The simplest type of phase detector is the XOR type, often called "Type 1", consisting of a single XOR gate. This outputs a square wave with a duty cycle proportional to the phase difference. When this signal is filtered by a low pass filter, it gives a voltage that is proportional to the phase difference. This type of detector covers a range of 180 degrees. When the inputs are in phase, the output duty cycle is 0%, when the inputs are 180 degrees out of phase, the output duty cycle is 100%. Above 180 degrees, the duty cycle starts decreasing again, falling to 0% at 360 degrees.
1444313273 33 FT0 Xor Pd Tf
The problem is that the phase in a resonant circuit swings through 180 degrees, and if the Q is high, this happens over a narrow frequency range. This is exactly the range covered by the phase detector, so it can be made to work. The problem comes when there is any additional phase shift, for example caused by delays in the IGBTs or the current sense transformer. If there is _any_ additional phase shift in the circuit, the phase will fall outside of the range of the detector and the output duty cycle will go in the opposite direction that it should. This will tell the VCO to increase the frequency when it should be decreased, and the VCO will go to the frequency limit and stick there. Here's a plot of what the transfer function will look like with 20 degrees of additional phase shift.
1444313272 33 FT0 Xor Phase Reversal
This is not guaranteed to happen in all cases, but it's likely to eventually show up. It took until the third revision of my induction heater before it showed up as a serious problem. That's the problem with marginal designs, they often work as they should then suddenly they don't. This can be generalized for all state-sensitive (combinatorial) phase detectors, any phase detector that only looks at the instantaneous value of the two inputs can only have a detection range of 180 degrees before the output wraps around.
The other common phase detector is the phase frequency detector. This type of phase detector looks at the edges of the two input signals. When the first edge comes, it starts charging or discharging the loop filter capacitor, and when the second edge comes, it stops. Whether it charges or discharges the capacitor depends on which edge comes first, if the edge from the VCO comes first, it starts discharging the loop filter capacitor. The result is that the VCO frequency is adjusted so that the edges come at the same time, that's the only way the VCO frequency is left at the same value.
1444313273 33 FT0 Pd2 Timing
The problem appears when this type of phase detector is used for sensing the tank phase, where both input frequencies are the same. If for example a glitch causes a false edge on the feedback input, the detector will loose track of which edge actually came first, and push the frequency in the wrong direction. I've illustrated this in the timing diagram above. The PLL will stay in this state, stuck at one of the ends of the range, until another glitch edge appears. What's even worse is, the PLL will often start up in this state and therefore never acquire lock in the first place. This problem was nicely described by Dr. Dark Current Link2 .
This situation can be generalized for all purely edge-triggered detectors. So where does that leave us? Both types of commonly used phase detectors are inherently unsuitable here. It turns out that there is a solution, and a very elegant one at that. A hybrid detector can be built which looks both at the edges and the states of the input. This type of detector can combine both the noise-immunity of the XOR type detector and the wide detection range of the edge sensitive detector. As an added bonus, this type of detector locks at zero degrees, so it can be used to lock series resonant tank current to the VCO frequency without any additional phase shifting tricks.
I have found this method documented in a paper [1], and a different, less elegant workaround is mentioned in an other paper by the same author [2]. Unfortunately, none of these are openly available on the web. I've therefore decided to document the method here. The detector is essentially the same as the edge sensitive detector, but the state machine is reset whenever the input signals are different. An even more elegant implementation is shown (without any further detail on the phase detector) in [3], and this is the one I've based my implementation on.
1444313273 33 FT0 Pd New
This implementation uses a D-flip flop to sample the feedback signal on the VCO clock edge, and uses this signal to select whether to increase or decrease the frequency. This gives it a +- 180 degree detection range. An XOR gate looks at the phase difference of the inputs, and applies the correction for the period that the signals are different by gating the output of the D-flip flop. Unfortunately, this type of phase detector can not be implemented from the phase detectors in the 4046 as we don't have access to some neccessary internal signals, but luckily it is easy to implement it with standard logic.
1444313273 33 FT0 Pd New Tinylogic
In my design I still chose to use the 4046 for its VCO and input amplifier, with the phase detector implemented with external logic. The design can be greatly simplified if a D-flip flop with output enable is used, and luckily these are available. I was able to implement the whole phase detector with two SOT23 devices at a total cost of under a dollar (about 25 cents in quantity 100). For fun, I made a quick 74HC4046-replacement with the new phase detector. It's pin compatible with the 74HC4046, but replaces the two phase comparators with the new one. I connected the new phase comparator output to both pin 2 and pin 13. This is a view of the underside of the board, where the components are mounted.
1444313273 33 FT0 4046 Repl
Note that I recently discovered this method, and I haven't yet received the parts to test it in practice, but the theory works out. I discussed these ideas with Steve Conner, and he's positive as well:
The stuff you told me over the last few days explains every weird anomaly I ever saw with my PLL drivers.
On a final note, I would highly recommend getting a copy of reference 3 for anybody interested in high frequency power electronics and especially Tesla coiling and induction heating. This paper contains a lot of very good information on high frequency resonant switching using IGBTs, and it presents a new method of power control. A prototype 100 kW 100 kHz IGBT inverter using 600 A bricks is presented, and they also do calorimetric efficiency measurements of different types of power control including phase shifting and detuning.
1: H. Karaca, "Phase detector for tuning circuit of resonant inverters",
Electronics Letters Vol. 36 No. 11, 25th May 2000
2: H. Karaca, "A malfunction problem and its solution in load resonant inverters ",
International Journal of Electronics, Volume 88, Issue 3, 2001
3: V. Esteve et al. "Enhanced Pulse-Density-Modulated Power Control for High Frequency Induction Heating Inverters",
IEEE Transactions on Industrial Electronics, Volume 62 Issue 11
Thu Oct 08 2015, 09:11PM
Excellent post! As I mentioned to Anders, when developing my PLL drivers, I noticed that the circuits using the type 1 phase detector sometimes failed to lock or got stuck, and the type 2 detector never worked for me at all. This post explains both problems nicely. Maybe it's time for a Mk3 PLL driver? smile
Dago
Fri Oct 09 2015, 07:59AM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
Interesting topic indeed!
I've been developing a fully digital induction heater driver and have run in to many many quite different approaches.
I've had an ARM-version working (not with an induction heater) Link2
Then I kinda figured using an MCU can be a bit problematic and an FPGA would be an optimal solution. I've had a couple different sort of working (in simulation) models made with VHDL (example Link2 ) but they both had some issues. That one has a phase-shift that is dependant on the frequency and I'd need a division to get rid of it and HW division is not nice. Then I made one version with a "type 2" PFD but so far have been unable to get it stable even though the filter should be fine and there should be phase margin.
Currently been reading this paper Link2 and implementing it but I'm quite not 100% sure how am I supposed to handle the value coming from the "P2D". It is a signed number representing the phase error but how do I feed this to the filter... The output of the filter controls a "phase accumulator" which only takes in a positive number and changes the frequency accordingly. How should I scale the the signed number from the P2D for the filter? Should I add the number to the last value and keep it always positive? But that would be an integrator which would change the response right? Any suggestions?
Uspring
Fri Oct 09 2015, 01:16PM
Nice post smile
I've seen phase detectors, which I think are made of a 3 state machine, states 1, 2 and 3. One clock counts the state number up, the other one down. States 1 and 3 bias VCO voltage up and down, respectively. I believe, your circuit works similarly, although negative clock transition seem also to affect it.
By increasing the number of states, the catch range can be increased.
Wolfram
Fri Oct 09 2015, 04:51PM
Dago wrote ...
Thanks.
Nice work. I am seriously considering migrating my own heater to an FPGA-based design at some point. Most of the conclusions from my first post apply to a PLL implemented digitally as well. Personally, I would make a phase accumulator oscillator, and just implement the loop integrator as a counter. The phase detector I described can be implemented directly in VHDL.
I don't have much time now, but I will try to get a chance to take a look at the paper over the weekend, but no guarantees. I find that if something is presented in a confusing way in a paper, it's often simpler to start from the basics and implement the idea from scratch using intuition.
Nice post
Thanks.
This is the second type of phase detector I described. It works fine when trying to lock the VCO to an external input, but doesn't work well for resonant tank control as I described in my first post. In a PLL controlled induction heater or SSTC, both input signals come from the VCO but one is phase shifted through the tank circuit. This type of phase detector works fine as long as it starts up in the right state, but if a glitch causes it to enter the wrong state, it will not be able to recover and end up stuck to one end of the frequency range, the timing diagram in the first post shows this scenario.
Adding more states will not help in this case, the only result will be that there are more states that it won't be able to recover from.
Edit:
The new phase detector is actually simpler than it looks, I find it easiest to understand it as follows;
The VCO is running at some frequency and outputting a square wave signal. This signal is amplified by the H bridge and sent to the tank circuit. The current through the tank circuit is measured, and what we're interested in is the phase relation between this signal and the VCO signal. This phase relationship tells us if we are above or below Fres, in other words which way we need to adjust the VCO frequency. This phase shift is normally between +90 and -90 degrees, but this range can be shifted a bit due to delays in the H bridge and phase shifts in the current sensing network.
On the rising edge of the VCO clock, the D flip flop samples the feedback signal. If we are below Fres, the feedback signal (basically the sign of the current waveform) will be '1' at this time (the current is leading the voltage by 90 degrees so we're at the peak of the current waveform). This signal is kept by the D flip flop until the next rising edge of the VCO output. Now the D flip flop output is high, indicating that the frequency should be adjusted up. This signal is sent to the loop filter as long as the XOR output is high, i.e. as long as the inputs are different. This is a time period corresponding to the phase difference between the inputs. If the phase is close to 0 degrees, only narrow pulses of "correction" current are injected into the integrating capacitor, and if they are perfectly in phase then no change in frequency is made. The voltage on this capacitor controls the VCO frequency directly.
BigBad
Sat Oct 10 2015, 05:53PM
If you know your frequency is between (say) 300-350khz then it it's possible to just use an arduino and undersample at (say) ~100khz frequencies. Once you've done that you can do much more complex PLL strategies, such as measuring the frequencies as well as the phase.
That will likely work extremely well unless the resonant frequency changes very quickly, I wouldn't have thought that that's a problem for induction heaters; but might be more problematic for Tesla coils where the resonance changes as it throws an arc.
Uspring
Mon Oct 12 2015, 10:06AM
Wolfram, thank you for the explanation. I understand now, why the 3 state machine won't work.
I still don't understand your second diagram. It seems to indicate, that resonance is achieved at 50% XOR duty cycle. That corresponds to 90 degrees phase shift in your first diagram. In your last post you write:
This phase relationship tells us if we are above or below Fres, in other words which way we need to adjust the VCO frequency. This phase shift is normally between +90 and -90 degrees...
That seems to indicate, that resonance is at 0 degrees. Perhaps a minor point, but a XOR works best around 90 degrees and the the new circuit around 0 degrees.
Wolfram
Mon Oct 12 2015, 06:21PM
BigBad wrote ...
This can work in theory but it will be difficult to get it working well in practice.
Your phase resolution will be inversely proportional to the difference between the VCO frequency and the closest integer multiple of the nyquist rate of your sampling frequency. For the induction heater, you want quite fine phase resolution, around the zero crossing even a few degrees can correspond to several amps of difference in switching current for the IGBTs. This means that you need to dynamically select the sampling frequency to be close to an integer fraction of your running frequency for acceptable performance. As you are undersampling, you're also very sensitive to sampling jitter, so you need to either sample using a hardware timer or do the code in assembly and count cycles.
I can't really think of any benefits of more complex PLL strategies. The purpose of the PLL is to find Fres and track it with an adjustable phase angle, and a plain analog PLL with my proposed phase detector does just that. Even if I had a microcontroller in my system, I would still strongly consider using the two 20 cent 74LVC1Gs.
Uspring wrote ...
Good point. I see that my original post was missing some information on this point. As the XOR phase detector transfer function has a reversal of the slope at zero degrees, it can't be used directly to lock tank current with bridge voltage. As the transfer function range is centered around 90 degrees, I introduced a 90 degree shift in my circuit to make the total phase shift 90 degrees at resonance. I did this by measuring tank cap voltage instead of tank current.
Carbon_Rod
Mon Oct 12 2015, 09:15PM
@BigBad
In general, the commercial driver circuits can include a number of design specific safeguards to try and mitigate issues with saturation and dynamic changes in the inductor during use. However, these can still fail given soft-starting the driver may not work if the initial inrush exceeds the coils rating plus the ripple current. Current regulation/monitoring may also be insufficient if the driver essentially experiences a fold-over prior to the feedback system tripping a limit. Additionally, the tolerances of both L & C components may drift around in non-linear ways, and even expensive switching output sections recommend a minimum 30% margin for SOA (realistically one can expect 20% for ceramic dialectic C, and 10% to 30% for L). Also, it may be counter intuitive to consider that an output section with ultra-fast freewheeling diodes may cause transients in the output section that can certainly damage the drivers.
However, adjusting the dwell times in the switching section could certainly be an advantage, as regulating the driver duty cycle at a specific frequency could avoid saturation related failures. Indeed, this is how most type III based regulators are intended to work. wink
Uspring
Tue Oct 13 2015, 09:04AM
An idea:
The FF in the new circuit determines which positive transition comes early. It is enabled as long as input signals are different. The phase detection speed can be doubled by adding the voltage from a similar circuit responsive to negative transitions. For the rapidly changing phases in a TC that might be an advantage.
